Value of timeout.tv_usec off by a factor of 1000
chrisj
Post by chrisj »
In zm_remote_camera.cpp, a timeval struct is initialized as follows:
                timeout.tv_sec = config.http_timeout/1000;
                timeout.tv_usec = config.http_timeout%1000;
Since the tv_usec field is supposed to be the number of microseconds, it should actually be initialized as:
               timeout.tv_usec = (config.http_timeout%1000) * 1000;
Since the value of config.http_timeout%1000 gives the remaining number of milliseconds not covered by the tv_sec field.
Not a big deal, really, but if you set the timeout to less than 1000ms, then you may notice the difference.
Normando
Post by Normando »
I have knoledge with C++ but it is a simple mathematics.
1 sec = 1000000 usec
So:
should be:
                timeout.tv_usec = config.http_timeout*1000;
Phil, can you confirm this?
zoneminder
Site Admin
Post by zoneminder »
The correct way is
however this is how it is currently implemented anyway.
You need to do the %1000 to get the milliseconds and then multiply by 1000 to get microseconds. Just multiplying by 1000 will include the seconds in the calculation and so will be too large.
Phil
Normando
Post by Normando »
Ohh, yes, I now I understand the concept.
Thanks for the clarification Phil
Regards
