How do I handle the situation when my camera automatically switch from day to night vision - this causes a lot of changes in the picture but I do not want it to trigger an alarm...
- Trist
Day to night switch....
- lazyleopard
- zoneminder
- Site Admin
- Contact:
You need to ensure that your preclusive zone is more sensitive (ie. has a smaller threshold and percentage values) than your regular zones for them to work effectively.
They're not a panacea though, and as with all tuning problems, the first step is to decide exactly what the qualities of changes you do or don't want triggered are. If you can't discriminate them in English (or whatever language you use) then the chances are you won't be able to set up a config that will do what you want.
Phil,
Phil,
- lazyleopard
- lazyleopard
- lazyleopard
