Vivotek 7138 issue
djsmiley
Vivotek 7138 issue
Post by djsmiley »
I have the same problem like this post: http://www.zoneminder.com/forums/viewto ... sc&start=0
I have three Vivotek 7138 IpCam, and i am having trouble with making this cameras work with RTSP mode in new 1.24.1 Zoneminder.
Here is the log messages:
Jun 18 11:54:48 nagios zmdc[25344]: INF [Starting pending process, zmc -m 2]
Jun 18 11:54:48 nagios zmdc[25344]: INF ['zmc -m 2' starting at 09/06/18 11:54:48, pid = 29867]
Jun 18 11:54:48 nagios zmdc[29867]: INF ['zmc -m 2' started at 09/06/18 11:54:48]
Jun 18 11:54:48 nagios zmc_m2[29867]: INF [Debug Level = 0, Debug Log = <none>]
Jun 18 11:54:48 nagios zmc_m2[29867]: INF [Starting Capture]
Jun 18 11:54:48 nagios zmc_m2[29867]: ERR [Unexpected response code 400, text is 'Bad Request']
Jun 18 11:54:53 nagios zmc_m2[29867]: FAT [No RTSP sources]
Jun 18 11:54:53 nagios zmc_m2[29867]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
Jun 18 11:54:53 nagios zmdc[25344]: ERR ['zmc -m 2' exited abnormally, exit status 6]
The configuration for this monitor is:
Remote prot: RTSP
Remote meth: RTP/RTSP
ip: x.x.x.x
port: 554
picture path: /live.sdp
remote host sub path: /trackID=
Can anybody help me with this problem?
Thanks for your help!
[/url]
kylejohnson
Post by kylejohnson »
I will never again buy a Vivotek product!
Have you tried without the sub path?
Have you looked around in the cameras settings? I know there are many options to configure regarding the port and the path.
djsmiley
Post by djsmiley »
Hmm, never again Vivotek? :) What product are comparable to Vivotek? (Primary subject is the price of course)
Now, i'm tried without the sub path, and here is the log output:
Jun 30 15:34:01 nagios zmdc[25344]: INF [Starting pending process, zmc -m 2]
Jun 30 15:34:01 nagios zmdc[25344]: INF ['zmc -m 2' starting at 09/06/30 15:34:01, pid = 30476]
Jun 30 15:34:01 nagios zmdc[30476]: INF ['zmc -m 2' started at 09/06/30 15:34:01]
Jun 30 15:34:01 nagios zmc_m2[30476]: INF [Debug Level = 0, Debug Log = <none>]
Jun 30 15:34:01 nagios zmc_m2[30476]: INF [Starting Capture]
Jun 30 15:34:01 nagios zmc_m2[30476]: ERR [Unexpected response code 400, text is 'Bad Request'
zoneminder
Site Admin
Post by zoneminder »
If you change to 1.24.2 then you no longer need (or can modify) the sub path so can throw that away. There are other changes also that may help. I have a Vivotek that works fine with port 554, RTP/Unicast and live.sdp as the host path.
Phil
djsmiley
Post by djsmiley »
Hi Phil,
Thanks for your suggestion, i'm upgraded to 1.24.2, but it does not works :(
Here is the syslog output.
Configuration is the same (ip, RTP/Unicast, port=554, live.sdp).
nagios:~# tail /var/log/syslog
Jul  2 11:57:38 nagios zmc_m1[13727]: WAR [Discarding packet for unrecognised ssrc 5a2f0397]
Jul  2 11:57:38 nagios zmc_m1[13727]: WAR [Discarding packet for unrecognised ssrc 1ccfd071]
Jul  2 11:57:38 nagios zmc_m1[13727]: WAR [Discarding packet for unrecognised ssrc bdd1b99b]
Jul  2 11:57:38 nagios zmc_m1[13727]: WAR [Discarding packet for unrecognised ssrc 5c430397]
Jul  2 11:57:38 nagios zmc_m1[13727]: WAR [Discarding packet for unrecognised ssrc c17bbd5d]
Jul  2 11:57:38 nagios zmc_m1[13727]: WAR [Discarding packet for unrecognised ssrc cdc8576b]
Jul  2 11:57:38 nagios zmc_m1[13727]: WAR [Discarding packet for unrecognised ssrc 5e5b0397]
Jul  2 11:57:38 nagios zmc_m1[13727]: WAR [Discarding packet for unrecognised ssrc afb9472e]
Jul  2 11:57:38 nagios zmc_m1[13727]: WAR [Discarding packet for unrecognised ssrc 686781cb]
Jul  2 11:57:38 nagios zmc_m1[13727]: WAR [Discarding packet for unrecognised ssrc 9b6df873]
Regards,
Zoltan
djsmiley
Post by djsmiley »
Maybe can i shomehow help you to debug this issue with this Vivotek cam?
Regards,
Zoltan
SyRenity
Post by SyRenity »
Hi.
I'm getting this issue too, with several models of Vivotek cameras that I have.
It seems to be related to the newest firmware used there.
From my code inspection, it seems the Vivotek produces different SSRC every time - can someone comment on this, and if it happens with other cameras?
Regards.
neuropa
Post by neuropa »
Seems like if ZM can't use RTSP on Vivotek cameras if build on 64 bit systems.
I have several installations of ZoneMinder, all with Vivotek IP cameras (FD7131). If I build version 1.24.2 on i386 all works great (according to instructions on the wiki), but if I build on X86_64 all attempts of getting images with RTSP result in black screen.
Can you investigate?
Elfe
Post by Elfe »
any updates for the 64bit users?
I use some Edimax 3010 and can only poll the still images :(
zmc_m21[-1].WAR-zm_rtp_data.cpp/57 [Discarding packet for unrecognised ssrc 1a1c11e2]
kenspank
Post by kenspank »
i'm using a 64-bit machine and don't even get a black screen. Help!
wasperen
new firmware also does not help
Post by wasperen »
Running 64 bits as well...
Just upgraded the camera to firmware 0200a... No change. Same
05/23/10 21:28:05.791151 zmc_m7[-1].WAR-zm_rtp_data.cpp/57 [Discarding packet for unrecognised ssrc 1a5e6cff]
05/23/10 21:28:05.792924 zmc_m7[-1].WAR-zm_rtp_data.cpp/57 [Discarding packet for unrecognised ssrc 7634dde9]
05/23/10 21:28:05.794959 zmc_m7[-1].WAR-zm_rtp_data.cpp/57 [Discarding packet for unrecognised ssrc 4cba154d]
ad infinitum...
The only option that I now have is through ffmpeg, but that just doesn't seem right.
Oh well... bring my IP7132 back I guess. :evil:
