state undefined and loooooong number
gian
Post by gian »
hi there,
on version 1.24.1, I notice after the "State: undefined" on the console, a loooooong numer: what does that mean? can I get rid of it...?
thanks,
-Gian
gian
Post by gian »
am I the only one?
the problem here is that the window size is tailored on the length of this number...
kwire
Post by kwire »
No, you're not the only one., I just get tired of posting the same reply over and over...
Take a look here... http://www.zoneminder.com/forums/viewto ... highlight=
I think you will find it fixed in 1.24.2 so maybe you could update???
Keith
gian
Post by gian »
sorry if I posted a silly question... I searched the forum before I posted, but probably with wrong keywords.
Thanks for your patience and support.
-Gian
kwire
Post by kwire »
Gian,
No question is "silly". I'm sorry if I was harsh, I know better than to answer when I am soooooo tired. ;)
As far as search, I just tried the keywords "state" and "undefined" (no quotes) and then selected "search for all terms" and it returned the threads I pointed you to.... I think the key is to use "search for all terms". Without it the search returns too many threads to be usefull.
Finally I see you asked in another thread how to update to 1.24.2. I don't know about Ubuntu , but did you compile your own Zoneminder? If so this thread might help you move from one version to another and back again if you need to...
HTH, Keith
gian
Post by gian »
I installed ZM with a .deb file.
Last time I upgraded, it was a pain.
Removed 1.23 and then I had to recreate all mySql stuff by hand, for some reason, because the .deb didn't.
