Supercircuits PC33CIPDN-4G Help
Hello all,
Has anyone successfully configured one of these IP cameras from Supercircuits in ZM?
I've been pulling my hair out trying every setting imaginable and can't get any video to ZM. (source stays in the red)
-Ubuntu 9.04 server 32 bit
-Dell poweredge t105 w/quad core amd
-followed the ubuntu installation walkthru on the ZM wiki page with no errors on install
help!
Thanks,
Landon
help!
Thanks,
Landon
on thing i forgot to mention is that also xawtv does not work. It might be a problem with the hardware but i'm just not sure (on board ATI video)
root@uam-crossett2:~# xawtv -hwscan
xdpyinfo: unable to open display "".
This is xawtv-3.95.dfsg.1, running on Linux/i686 (2.6.28-11-server)
Error: Can't open display:
Re: Supercircuits PC33CIPDN-4G Help
You can try connecting with ffmpeg to:
rtsp://<camera ip>/mpeg4/media.3gp
If you can pull a image that should be the correct path for RTSP streaming. Supercircuits likes to rebrand Topica cameras which is what the camera is....most likely using their ip modules. I'll check tomorrow to see what the MJPEG path is
Guys thanks for the help so far. Curtis the path you gave me worked in VLC! Still not getting any video to ZM. Here are my settings
remote protocol: RTSP
remote method: RTP/RTSP (I also tried RTP/Unicast)
remote host name: 10.9.16.40
remote host port: 7070
remote host path: rtsp://10.9.16.40/mpeg4/media.3gp
here is setup info output from the actual camera:
WAN_TYPE='2'
WAN_IP='10.9.16.40'
WAN_NETMASK='255.255.240.0'
WAN_GATEWAY='10.9.16.1'
WAN_PPPOE_USERNAME=''
WAN_PPPOE_PASSWORD=''
SPEED_WAN='0'
LANGUAGE='0'
PORT_HTTP='80'
PORT_SEARCH_1='6005'
PORT_SEARCH_2='6006'
LAN_HOSTNAME='camera1'
DHCP_BY_HOSTNAME='0'
DNS_PRIMARY='10.2.6.74'
DNS_SECONDARY='10.2.6.71'
DDNS_TYPE='1'
DDNS_HOSTNAME=''
DDNS_SERVICE='dyndns'
DDNS_USERNAME=''
DDNS_PASSWORD=''
DDNS_SERVER=''
DATE_TYPE='2'
DATE_SNTP_IP='192.168.0.2'
DATE_SNTP_UPDATE='86400'
DATE_MANUAL_DATE='010100002004'
DATE_MANUAL_TIME='00:00:00'
DATE_MANUAL_ZONE='+00'
DAYLIGHT_SAVING_CONFIG='0,1,3,2,2,7,1,10,1,3,7'
VIDEO_ENCODER='MPEG4'
VIDEO_TV='NTSC'
VIDEO_RESOLUTION='N720x480'
VIDEO_BITRATE='1.2M'
VIDEO_MAX_BITRATE='UNLIMITED'
VIDEO_FPS='MODE1'
VIDEO_VARIABLE_FPS='30'
VIDEO_MOTION_TYPE='0'
VIDEO_MOTION_ENABLED='0x00'
VIDEO_MOTION1_STATE='0'
VIDEO_MOTION1_SX='0'
VIDEO_MOTION1_SY='0'
VIDEO_MOTION1_EX='0'
VIDEO_MOTION1_EY='0'
VIDEO_MOTION1_SEN='70'
VIDEO_MOTION1_TIME='1'
VIDEO_MOTION1_OBJ='10'
VIDEO_MOTION2_STATE='0'
VIDEO_MOTION2_SX='0'
VIDEO_MOTION2_SY='0'
VIDEO_MOTION2_EX='0'
VIDEO_MOTION2_EY='0'
VIDEO_MOTION2_SEN='70'
VIDEO_MOTION2_TIME='1'
VIDEO_MOTION2_OBJ='10'
VIDEO_MOTION3_STATE='0'
VIDEO_MOTION3_SX='0'
VIDEO_MOTION3_SY='0'
VIDEO_MOTION3_EX='0'
VIDEO_MOTION3_EY='0'
VIDEO_MOTION3_SEN='70'
VIDEO_MOTION3_TIME='1'
VIDEO_MOTION3_OBJ='10'
VIDEO_BRIGHTNESS='63'
VIDEO_CONTRAST='51'
VIDEO_SATURATION='85'
VIDEO_HUE='50'
VIDEO_WB_MODE='0'
VIDEO_WB_RGAIN='0'
VIDEO_WB_BGAIN='0'
VIDEO_AGC_GAIN='0'
VIDEO_EXPOSURE_MODE='1'
VIDEO_EXP_GAIN='0'
VIDEO_SHUTTER_MODE='1'
VIDEO_SHUTTER_SPEED='1'
VIDEO_IRIS_MODE='0'
VIDEO_IRIS='0'
IRIS_LEVEL_AUTO='96'
IRIS_LEVEL_FIX='0'
SENSE_UP='0'
DAYNIGHT_MODE='2'
VIDEO_FLICKLESS='1'
VIDEO_BLC='0'
VIDEO_MAX_SHUTTER='0'
LENS_COMPENSATION='1'
VIDEO_FLIP_MODE='0'
VIDEO_MIRROR_MODE='0'
DAY_GAIN_THD='80'
VIDEO_SHARPNESS='0'
VIDEO_MPEG4_QUALITY='NONE'
VIDEO_FPS_NUM='30'
VIDEO_MJPEG_QUALITY='50'
VIDEO_MJPEG_FPS='30'
EPTZ_STATE='0'
EPTZ_RESOLUTION='N640x480'
EPTZ_FPS='MODE1'
EPTZ_FPS_VARIABLE='30'
EPTZ_FPS_NUM='30'
EPTZ_POSITION='0,0'
PTZ_VENDOR='0x1'
PTZ_PROTOCOL='0x100'
PTZ_STATE='0'
PTZ_PRESET='0'
PTZ_SPEED_PAN='0x0'
PTZ_SPEED_TILT='0x0'
PTZ_POS_PAN='0x0'
PTZ_POS_TILT='0x0'
PTZ_MAX_SPEED_PAN='0x5'
PTZ_MAX_SPEED_TILT='0x5'
PTZ_MOVE_LIMIT='0xffff,0xffff,0xffff,0xffff'
PTZ_MOVE_LIMIT_DEF='0xffff,0xffff,0xffff,0xffff'
PTZ_FOCUS_MODE='0'
PTZ_POS_FOCUS='0x0'
PTZ_IRIS_MODE='0'
PTZ_POS_IRIS='0x0'
PTZ_SPEED_ZOOM='0x0'
PTZ_POS_ZOOM='0x0'
PTZ_PRESET_01='0,0x0,0x0,0x0,5,5,7,10,Entry 01'
PTZ_PRESET_02='0,0x0,0x0,0x0,5,5,7,10,Entry 02'
PTZ_PRESET_03='0,0x0,0x0,0x0,5,5,7,10,Entry 03'
PTZ_PRESET_04='0,0x0,0x0,0x0,5,5,7,10,Entry 04'
PTZ_PRESET_05='0,0x0,0x0,0x0,5,5,7,10,Entry 05'
PTZ_PRESET_06='0,0x0,0x0,0x0,5,5,7,10,Entry 06'
PTZ_PRESET_07='0,0x0,0x0,0x0,5,5,7,10,Entry 07'
PTZ_PRESET_08='0,0x0,0x0,0x0,5,5,7,10,Entry 08'
PTZ_PRESET_09='0,0x0,0x0,0x0,5,5,7,10,Entry 09'
PTZ_PRESET_10='0,0x0,0x0,0x0,5,5,7,10,Entry 10'
PTZ_PRESET_11='0,0x0,0x0,0x0,5,5,7,10,Entry 11'
PTZ_PRESET_12='0,0x0,0x0,0x0,5,5,7,10,Entry 12'
PTZ_PRESET_13='0,0x0,0x0,0x0,5,5,7,10,Entry 13'
PTZ_PRESET_14='0,0x0,0x0,0x0,5,5,7,10,Entry 14'
PTZ_PRESET_15='0,0x0,0x0,0x0,5,5,7,10,Entry 15'
PTZ_PRESET_16='0,0x0,0x0,0x0,5,5,7,10,Entry 16'
PTZ_PRESET_17='0,0x0,0x0,0x0,5,5,7,10,Entry 17'
PTZ_PRESET_18='0,0x0,0x0,0x0,5,5,7,10,Entry 18'
PTZ_PRESET_19='0,0x0,0x0,0x0,5,5,7,10,Entry 19'
PTZ_PRESET_20='0,0x0,0x0,0x0,5,5,7,10,Entry 20'
PTZ_PRESET_21='0,0x0,0x0,0x0,5,5,7,10,Entry 21'
PTZ_PRESET_22='0,0x0,0x0,0x0,5,5,7,10,Entry 22'
PTZ_PRESET_23='0,0x0,0x0,0x0,5,5,7,10,Entry 23'
PTZ_PRESET_24='0,0x0,0x0,0x0,5,5,7,10,Entry 24'
PTZ_PRESET_25='0,0x0,0x0,0x0,5,5,7,10,Entry 25'
PTZ_PRESET_26='0,0x0,0x0,0x0,5,5,7,10,Entry 26'
PTZ_PRESET_27='0,0x0,0x0,0x0,5,5,7,10,Entry 27'
PTZ_PRESET_28='0,0x0,0x0,0x0,5,5,7,10,Entry 28'
PTZ_PRESET_29='0,0x0,0x0,0x0,5,5,7,10,Entry 29'
PTZ_PRESET_30='0,0x0,0x0,0x0,5,5,7,10,Entry 30'
PTZ_PRESET_31='0,0x0,0x0,0x0,5,5,7,10,Entry 31'
PTZ_PRESET_32='0,0x0,0x0,0x0,5,5,7,10,Entry 32'
PTZ_TOUR_STATE='DISABLE'
PTZ_TOUR01_NAME='TOUR 1'
PTZ_TOUR01_01='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR01_02='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR01_03='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR01_04='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR02_NAME='TOUR 2'
PTZ_TOUR02_01='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR02_02='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR02_03='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR02_04='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR03_NAME='TOUR 3'
PTZ_TOUR03_01='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR03_02='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR03_03='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR03_04='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR04_NAME='TOUR 4'
PTZ_TOUR04_01='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR04_02='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR04_03='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR04_04='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR05_NAME='TOUR 5'
PTZ_TOUR05_01='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR05_02='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR05_03='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR05_04='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR06_NAME='TOUR 6'
PTZ_TOUR06_01='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR06_02='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR06_03='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR06_04='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR07_NAME='TOUR 7'
PTZ_TOUR07_01='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR07_02='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR07_03='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR07_04='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR08_NAME='TOUR 8'
PTZ_TOUR08_01='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR08_02='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR08_03='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR08_04='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR09_NAME='TOUR 9'
PTZ_TOUR09_01='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR09_02='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR09_03='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR09_04='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR10_NAME='TOUR 10'
PTZ_TOUR10_01='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR10_02='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR10_03='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR10_04='0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1,0,1,10,1'
PTZ_TOUR_SCAN='1,0,0x0,0x0'
PTZ_PARK_CONFIG='0,10'
ACCOUNT_ROOT_NAME='admin'
ACCOUNT_ROOT_PASSWORD='123456'
ACCOUNT_USER_NAME_1=''
ACCOUNT_USER_PASSWORD_1=''
ACCOUNT_USER_NAME_2=''
ACCOUNT_USER_PASSWORD_2=''
ACCOUNT_USER_NAME_3=''
ACCOUNT_USER_PASSWORD_3=''
ACCOUNT_USER_NAME_4=''
ACCOUNT_USER_PASSWORD_4=''
ACCOUNT_USER_NAME_5=''
ACCOUNT_USER_PASSWORD_5=''
ACCOUNT_USER_NAME_6=''
ACCOUNT_USER_PASSWORD_6=''
ACCOUNT_USER_NAME_7=''
ACCOUNT_USER_PASSWORD_7=''
ACCOUNT_USER_NAME_8=''
ACCOUNT_USER_PASSWORD_8=''
ACCOUNT_USER_NAME_9=''
ACCOUNT_USER_PASSWORD_9=''
ACCOUNT_USER_NAME_10=''
ACCOUNT_USER_PASSWORD_10=''
VIDEO_CAMERA_NAME='Camera-1'
V2_STREAMING_METHOD='3' <------ ## (RTP over UDP)##
PORT_CONTROL='6001'
PORT_VIDEO='6002'
PORT_MULTICAST='5000'
V2_MULTICAST_IP='228.5.6.1'
VIDEO_MULTICAST_TTL='16'
IGMP_ENABLED='0'
RTSP_AUTHEN='0'
RTP_B2='1'
V2_PORT_RTSP='7070'
V2_PORT_RTP_MULTI_VIDEO='5000'
V2_PORT_RTP_MULTI_AUDIO='5002'
RTP_MULTICAST_STREAMING='PAUSE'
VIDEO_TOS_TYPE='1'
VIDEO_TOS_PRIORITY='Normal-Service'
VIDEO_RS485_LINECONTROL='0x00'
VIDEO_RS485_BAUDRATE='0x03'
V2_AUDIO_ENABLED='0'
AUDIO_IN_SENSITIVITY='HIGH'
AUDIO_OUT_VOLUME='0'
EVENT_ENABLED='0'
EVENT_TIME_PRE='1'
EVENT_TIME_POST='1'
EVENT_TIME_INTERVAL='1'
MD2DO1='0,1,1'
MD2DO2='0,2,1'
LAYOUT_FOOTER_COPYRIGHT='Supercircuits PC33C-4G IP Series'
COMPANY_NAME='Supercircuits PC33C-4G IP Series'
COMPANY_URL='http://www.supercircuits.com'
ACTIVEX_URL=''
Last thing and i don't know if it matters, in the ZM options i have
MPEG_LIVE_FORMAT and MPEG_REPLAY_FORMAT set to mpeg. also the cambozola option is checked.
Definitely making progress; i almost spilled my coffee all over my keyboard this morning when the stream came thru on VLC =)
Landon
WAN_TYPE='2'
WAN_IP='10.9.16.40'
SPEED_WAN='0'
LANGUAGE='0'
PORT_HTTP='80'
DDNS_TYPE='1'
DDNS_HOSTNAME=''
DDNS_USERNAME=''
DDNS_PASSWORD=''
DDNS_SERVER=''
DATE_TYPE='2'
VIDEO_TV='NTSC'
VIDEO_FPS='MODE1'
VIDEO_CONTRAST='51'
VIDEO_HUE='50'
VIDEO_WB_MODE='0'
VIDEO_WB_RGAIN='0'
VIDEO_WB_BGAIN='0'
VIDEO_AGC_GAIN='0'
VIDEO_EXP_GAIN='0'
VIDEO_IRIS_MODE='0'
VIDEO_IRIS='0'
IRIS_LEVEL_FIX='0'
SENSE_UP='0'
DAYNIGHT_MODE='2'
VIDEO_FLICKLESS='1'
VIDEO_BLC='0'
VIDEO_FLIP_MODE='0'
DAY_GAIN_THD='80'
VIDEO_SHARPNESS='0'
VIDEO_FPS_NUM='30'
EPTZ_STATE='0'
EPTZ_FPS='MODE1'
EPTZ_FPS_NUM='30'
EPTZ_POSITION='0,0'
PTZ_VENDOR='0x1'
PTZ_STATE='0'
PTZ_PRESET='0'
PTZ_SPEED_PAN='0x0'
PTZ_POS_PAN='0x0'
PTZ_POS_TILT='0x0'
PTZ_FOCUS_MODE='0'
PTZ_POS_FOCUS='0x0'
PTZ_IRIS_MODE='0'
PTZ_POS_IRIS='0x0'
PTZ_POS_ZOOM='0x0'
PORT_CONTROL='6001'
PORT_VIDEO='6002'
IGMP_ENABLED='0'
RTSP_AUTHEN='0'
RTP_B2='1'
V2_PORT_RTSP='7070'
VIDEO_TOS_TYPE='1'
EVENT_ENABLED='0'
EVENT_TIME_PRE='1'
EVENT_TIME_POST='1'
MD2DO1='0,1,1'
MD2DO2='0,2,1'
ACTIVEX_URL=''
Landon
update
I called supercircuits and spoke with a tech again. He told me this time that those cameras (pc33cipdn-4g) use the ACTI protocols.
so..time to scavenge the forums for the acti image path script and i should be good to go. If someone knows it off hand and wants to place it here in this thread, that would be great (for me and future users of this camera perhaps).
*crosses fingers* will keep yall posted till this gets figured out.
thanks,
Landon
thanks,
Landon
just tried the preset
it filled in everything except the remote host path and here is what it looks like:
remote method: RTP/Unicast
remote host path: rtsp://10.9.16.40:7070/tmp/cam.avi
-- still nothing in ZM (source is in red and no video), works fine streaming through VLC with that path
far as i can tell everything looks good in the setup (bearing in mind i'm a zoneminder supernoob). could this be a video card issue (on board ati) ?
here is output from the tail /var/log/messages as a side note:
Jul 8 14:37:43 uam-crossett2 zmdc[15031]: INF ['zmc -m 2' started at 09/07/08 14:37:43]
Jul 8 14:37:43 uam-crossett2 zmc_m2[15031]: INF [Debug Level = 0, Debug Log = <none>]
Jul 8 14:38:23 uam-crossett2 zmdc[14946]: INF [Starting pending process, zmc -m 2]
Jul 8 14:38:23 uam-crossett2 zmdc[14946]: INF ['zmc -m 2' starting at 09/07/08 14:38:23, pid = 15033]
Jul 8 14:38:23 uam-crossett2 zmdc[15033]: INF ['zmc -m 2' started at 09/07/08 14:38:23]
Jul 8 14:38:23 uam-crossett2 zmc_m2[15033]: INF [Debug Level = 0, Debug Log = <none>]
Jul 8 14:39:43 uam-crossett2 zmdc[14946]: INF [Starting pending process, zmc -m 2]
Jul 8 14:39:43 uam-crossett2 zmdc[14946]: INF ['zmc -m 2' starting at 09/07/08 14:39:43, pid = 15054]
Jul 8 14:39:43 uam-crossett2 zmdc[15054]: INF ['zmc -m 2' started at 09/07/08 14:39:43]
Jul 8 14:39:43 uam-crossett2 zmc_m2[15054]: INF [Debug Level = 0, Debug Log = <none>]
Also the video card won't make any difference...it's a configuration issue with Zoneminder or the camera
PC33CIPDN-4G
hey guys,
any luck with that camera yet ?
cordel, i spoke to a sales guy there today and asked him to see if they could put one on the net for a few days. if they do, could you check to see if it will work with mjpeg streaming, with zoneminder 1.23.3 ?
clay
clay
