No error no image!!
billybolly
Post by billybolly »
I put all cameras in modect mode and they are all green without image!
On log file I get for each one:
06/17/09 16:17:26.641843 zms[-1].INF-zm_debug.c/292 [New Debug Level = 3, New Debug Log = /var/log/zm/zm_debug.log.08068]
06/17/09 16:17:26.642171 zms[-1].DB1-zms.cpp/92 [Query: mode=jpeg&monitor=3&scale=100&maxfps=15&buffer=1000&connkey=577948&rand=1245244646]
06/17/09 16:17:26.642997 zms[-1].DB1-zm_monitor.cpp/2260 [Got 1 monitors]
06/17/09 16:17:26.643283 zms[-1].DB1-zm_monitor.cpp/338 [monitor purpose=0]
06/17/09 16:17:26.643294 zms[-1].DB1-zm_monitor.cpp/345 [mem.size=3025524]
06/17/09 16:17:26.643400 zms[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 180x140 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
06/17/09 16:17:26.643740 zms[-1].DB1-zm_monitor.cpp/458 [Monitor BarB has function 2]
06/17/09 16:17:26.643750 zms[-1].DB1-zm_monitor.cpp/459 [Monitor BarB LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
06/17/09 16:17:26.643757 zms[-1].DB1-zm_monitor.cpp/460 [Monitor BarB IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
06/17/09 16:17:26.643773 zms[-1].DB1-zm_monitor.cpp/2457 [Loaded monitor 3(BarB), 0 zones]
06/17/09 16:17:26.643905 zms[-1].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
06/17/09 16:17:26.643926 zms[-1].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
06/17/09 16:17:26.644089 zms[-1].DB2-zm_monitor.cpp/3342 [Checking swap image location]
06/17/09 16:17:26.644100 zms[-1].DB3-zm_monitor.cpp/3343 [Checking swap image path]
06/17/09 16:17:26.644143 zms[-1].DB3-zm_monitor.cpp/2866 [Swap path '/tmp/zmswap-m3/zmswap-q577948' missing, creating]
06/17/09 16:17:26.644205 zms[-1].DB2-zm_monitor.cpp/3364 [Assigning temporary buffer]
06/17/09 16:17:26.651510 zms[-1].DB2-zm_monitor.cpp/3367 [Assigned temporary buffer]
06/17/09 16:17:27.651736 zms[-1].DB2-zm_monitor.cpp/2917 [Got message, type 1, msg 99]
06/17/09 16:17:27.651786 zms[-1].DB1-zm_monitor.cpp/3123 [Got QUERY command, sending STATUS]
06/17/09 16:17:27.651798 zms[-1].DB2-zm_monitor.cpp/3171 [L:0, D:0, P:0, R:100, d:1245244647.652, Z:100, E:1 F:0]
06/17/09 16:17:27.651864 zms[-1].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
06/17/09 16:17:27.651874 zms[-1].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
06/17/09 16:17:31.152282 zms[-1].DB2-zm_monitor.cpp/2917 [Got message, type 1, msg 99]
06/17/09 16:17:31.152342 zms[-1].DB1-zm_monitor.cpp/3123 [Got QUERY command, sending STATUS]
06/17/09 16:17:31.152354 zms[-1].DB2-zm_monitor.cpp/3171 [L:0, D:0, P:0, R:100, d:1245244651.152, Z:100, E:1 F:0]
06/17/09 16:17:31.152399 zms[-1].DB3-zm_stream.cpp/58 [FPS:0.00, MXFPS:15, BFPS:0, EFPS:0, FM:1]
06/17/09 16:17:31.152409 zms[-1].DB3-zm_stream.cpp/65 [aEFPS:0, aFM:1]
what is the error?
billybolly
solved !!!!!!!!!!!!!!!
automatically !
Yesterday I made a kernel update of my 64 bit Opensuse 11.1 and the cameras worked !!! all with settings as described in the articles for each model, Edimax IC-1510 and DCS-900.
It is crusial to have the same settings in resolution (e.g 640X480) in the camera and the "zoneminder"
Thanks!
liviab
"Waiting for capture daemon"
Post by liviab »
Automatically??
:shock:
I'm having the same problem... :?
The console is reloading all the time and /var/log/message shows "Waiting for capture daemon" all the time too.
The debug file is showing the same as yours.
What could it be?
cordel
Post by cordel »
billybolly wrote:solved !!!!!!!!!!!!!!!
automatically !
Thanks!
Sorry, I was never able to log in, every time you PMed a new IP I was not able to get to it before your IP changed.
Glad you have it sorted, the image size and http version were on my list of things to check for you. It is something you have done, as the Kernel don't really have to much to do with IP cams. Maybe the reboot helped.
liviab
Post by liviab »
:D
I changed the "Remote Method" to "regexp" and the ZoneMinder worked fine.
But I don't understand why... =/
Although it's working, there are warnings and errors with/about JPEG.
