I've followed the build and install guides on the wiki several times with the same results.
Zoneminder and ffmpeg where built from the svn repositories. I even went back to the
ffmpeg 0.5 and zoneminder 1.24.1 bases but no luck there either.
zmc is crashing with signal 8 (floating point exception). At this point I'm not sure if it's a shared memory, zmc, 64 bit O/S or combination.
When I turn on debug I'm seeing that the capture daemon does grab frames but gets errors trying to decode the frame. Am I correct to assume if zmc is getting frames
then shared memory is working?
ffmpeg works capturing video streams from the camera using rtsp and I can playback with mplayer.
I'm running out of ideas. does anyone out there have any clues whats going on here?
Any help and/or suggestions would be greatly appreciated.
Thank you.
zmdc.log:
Jul 9 08:29:37 zm1 zmc_m1[9156]: INF [Starting Capture]
Jul 9 08:29:37 zm1 zmdc[9111]: WAR [Can't find process with command of 'zma -m
1']
Jul 9 08:29:39 zm1 zmc_m1[9156]: ERR [Error while decoding frame 1]
Jul 9 08:29:39 zm1 zmc_m1[9156]: ERR [256: 74 88 a4 73 9a 5a 1c bc a3 a1 a1 20
e0 1d 05 ca 48 17 a0 e5 82 64 ec 1d a3 30 71 f0 76 8d d1 c3 e5 62 10 84 33 47 60
e1 58 38 15 d4 fe a4 5c 1c 5a 7c 46 d0 e4 3c 58 4c 56 b0 e4 26 e2 76 87 03 91 b
1 39 47 13 73 b1 09 30 0a 11 a6 52 54 dd 28 a5 90 9d 18 72 56 23 a0 77 01 c2 12
02 39 b8 88 a9 a6 97 b6 6a 47 39 36 9b 59 1a 06 d3 f0 5e 9a 71 7a 38 4a 1c 3b 81
c2 3c 65 7a 22 ad b1 c8 70 37 4b 88 88 c4 6d 54 83 bd ce a4 95 85 86 fa 48 9b 7
b 5b e7 17 a1 b0 8d 39 1d 57 4e 58 9d 31 31 49 69 a0 71 20 8f 21 07 60 7e 31 67
4b 22 5d bc 17 0e 42 fd 36 99 18 39 be 30 38 23 c0 74 29 29 26 04 66 ca 70 6a de
8e ae 51 c4 2c 09 84 75 dd 2d 2a 15 62 f7 31 42 cd a4 16 de 23 a8 3d 7d 9a 97 9
4 dd 6e f6 b7 6e ae c8 b5 0a 73 e2 37 60 a9 27 18 65 96 57 38 54 ca 40 f4 09 86
62 18 a8 18]
root@:/tmp# ipcs -m
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x7a6d0001 262144 www-data 700 36865524 1
0x7a6d0002 294913 www-data 700 36865524 1
root@:/tmp# sysctl -a | grep shm
kernel.shmmax = 4194304000
kernel.shmall = 2048000
kernel.shmmni = 4096
[Thu Jul 09 10:31:32 2009] [error] [client 10.16.1.95] array (\n 0 => \n array (\n 'file' => '/srv/zm/www/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-017705s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/srv/zm/www/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/srv/zm/www/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://zoneminder.merfinllc.com/index.php?view=watch&mid=2
Jul 9 11:01:39 zm1 zmc_m1[23559]: INF [Got signal 11 (Segmentation fault), crashing]
Jul 9 11:01:39 zm1 zmc_m1[23559]: ERR [Signal address is 0x10206, no eip]
Jul 9 11:01:39 zm1 zmc_m1[23559]: ERR [Backtrace: /lib/libpthread.so.0 [0x7f82523ac0f0]]
Jul 9 11:01:39 zm1 zmc_m1[23559]: ERR [Backtrace: /lib/libc.so.6(memcpy+0x15b) [0x7f82512e424b]]
Jul 9 11:01:39 zm1 zmc_m1[23559]: ERR [Backtrace: /usr/local/bin/zmc [0x43604a]]
Jul 9 11:01:39 zm1 zmc_m1[23559]: ERR [Backtrace: /usr/local/bin/zmc [0x43a43e]]
Jul 9 11:01:39 zm1 zmc_m1[23559]: ERR [Backtrace: /usr/local/bin/zmc [0x43912a]]
Jul 9 11:01:39 zm1 zmc_m1[23559]: ERR [Backtrace: /usr/local/bin/zmc [0x44bb85]]
Jul 9 11:01:39 zm1 zmc_m1[23559]: ERR [Backtrace: /lib/libpthread.so.0 [0x7f82523a43ea]]
Jul 9 11:01:39 zm1 zmc_m1[23559]: ERR [Backtrace: /lib/libc.so.6(clone+0x6d) [0x7f8251345cbd]]
Jul 9 11:01:39 zm1 zmc_m1[23559]: INF [Backtrace complete, please execute the following command for more information]
Jul 9 11:01:39 zm1 zmc_m1[23559]: INF [addr2line -e /lib/libc.so.6(clone+0x6d) 0x7f82523ac0f0 0x7f82512e424b 0x43604a 0x43a43e 0x43912a 0x44bb85 0x7f82523a43ea 0x7f8251345cbd]
Jul 9 11:01:39 zm1 zmdc[23436]: ERR ['zmc -m 1' exited abnormally, exit status 11]
Jul 9 11:01:43 zm1 zmwatch[23468]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Jul 9 11:04:44 zm1 zmwatch[23468]: INF [Restarting capture daemon for CompRmWest, time since last capture 15 seconds (1247162684-1247162669)]
Jul 9 11:04:44 zm1 zmdc[23436]: INF ['zmc -m 1' starting at 09/07/09 11:04:44, pid = 23614]
/usr/src/ffmpeg# ./configure --enable-shared --enable-pthreads --arch=x86_64
/usr/src/zm# ./configure --with-webdir=/srv/zm/www --with-cgidir=/srv/zm/www/cgi-bin \
--enable-debug=yes --with-webgroup=www-data --with-webuser=www-data \
ZM_SSL_LIB=openssl ZM_DB_HOST=localhost ZM_DB_NAME=zm \
ZM_DB_USER=zmuser ZM_DB_PASS=zmpass
Jul 9 11:32:33 zm1 zmc_m1[24112]: WAR [Discarding packet for unrecognised ssrc 57c0a53a]
Jul 9 11:32:33 zm1 zmc_m1[24112]: WAR [Discarding packet for unrecognised ssrc 23c155ce]
Jul 9 11:32:33 zm1 zmc_m1[24112]: WAR [Discarding packet for unrecognised ssrc 8401aa73]
Jul 9 11:32:33 zm1 zmc_m1[24112]: WAR [Discarding packet for unrecognised ssrc 6e8440cb]
