How do I get ZM to backup the video stored on the ZM machine to a remote computer's harddrive. I would like to do this in case the ZM machine is stolen (it is located at the same site as the cameras), the video will be constantly backed up to the remote device.
Also, any suggestions on how to go about choosing cameras? What are the features that determine my needs.
Remote Video Storage
I was thinking of a program that dynamically backs up data if there is any change to the file and does so immediately. the point i guess would be that in the event of a burgulary and the perpetrator takes the zoneminder machine that has the stored video, atleast some of it would have been transferred to the remote location.
Don't forget bandwidth. How fat's your pipe to the remote location, and how many cameras do you have? Real time syncing of the amount of cameras I have vs the amount of pipe i have going out wouldn't work for me. Perhaps just a camera facing the ZM server itself (or out from it, whichever would give you a better facial angle) that syncs in real-time with motion would be easier to pull off.
