Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
Things that caused me trouble.
Login with admin admin
Make sure you have a user with stream for the name and password on the server
Under settings and monitor, put the ip address in only, make sure URL is NOT checked
Finally, make sure you have a colon : before the port
I hope this helps someone.
if you really mean zm4linux then i dont develop that anymore and i dont think you can chnage the default open view.
You can on zm4ms. if thats what you meant
James Wilson
Is there a post with instructions on how to use ZM4MS? 46 pages is a bit to search through and it starts several years back with the older versions.
It would be useful to post a link on the first post if there is something which says how to setup ZM4MS.
EDIT: OK, I was a moron. I wasn't changing the usernames correctly. I found the bit on the first page at the bottom below the screenshots. As a suggestion, you might move those brief instructions to the top above the images. The funny thing is that I read about 30 pages before I saw reference to the instructions on the first page.
Axis 207
Hi, first thank you James for your extraordinary Viewer.
I can set up it with out problems through Zoneminder but I can't set up an external camera (Axis 207), I what to connect this external camera directly to the Viewer.
I have the same user and pass in the camera and in the Viewer.
I tried:
IP/URL : user:pass@192.168.1.200
PORT: 80
SITE-NAMES enable: /axis-cgi/jpg/image.cgi?resolution=640x480 [checked]
*URL: [checked]
and also a lot of combinations with http:// and bla,bla,bla..
No luck.
Could you help me?
Thanks.
J.
I tried:
PORT: 80
*URL: [checked]
No luck.
Could you help me?
Thanks.
J.
Here is how I have mine set up. The default login is admin, password admin.
Click setup, the tools looking icon.
Monitors Tab: type in the IP and monitor number. For the number, go to the zoneminder web console, mouse over (or open) the monitor name. Read the link. The mid=1 is monitor id 1. Put that in the MON field. Type in a description if you want. It should look like:
Refresh Rates and Views Tab: Click the check boxes for the buttons you want for the number of cameras to display.
Users Tab: This is key, your users here should match the users you have in Zoneminder. Make sure that the user you want to use is in zoneminder also.
http://rx2-zone/index.php?view=monitor&mid=1
I actually read all 46 pages of this post and I did see somewhere here that others have done this. You need the IP to be the IP and then the path to be everything after the /.
As for the login I am not sure, I would assume it needs to match the user info in ZM. If it uses standard http://user:pass@ipaddress/path/to/image format you might be able to use the user:pass@ipaddress, but again I am not sure.
I am still fighting with this, first correct step
in the IP/URL must be the IP address with this format:
http://user:pass@192.168.1.100
and in PORT
just, 80
with this format I can see transfering of packets but the camera reply with packets like this:
Your browser has JavaScript turned off..... blaaaaa
Fknnn cam.
and in PORT
just, 80
Fknnn cam.
Ok now is working, the thing was that the Viewer don't authenticate when send the http packet.
I create in my camera a login without auth and I puted just this in IP/URL
http://ipaddress/mypaht_to_image
PORT 80
nothing else but still with problems, I am receiving errors like this:
A)
PROGRAM SETTINGS: Conversion from string ::to type 'Integer' is not valid
B)
DUAL HEAD:
Conversion form string"" to type 'Integer' is not valid
Other thing:
The image are slow I thought it will be similar quality as in firefox.
PORT 80
A)
B)
DUAL HEAD:
Other thing:
The speed is adjusted on the Refresh Rates and Views tab in settings.
Take a look at the Misc section for the dual head settings, possibly something other than a number in there?
As for program settings, I'd check the option boxes in all fields looking for something expects a number, but has text in it.
