Hi!
Is searched and searched but haven't find any reference on this error.
When i "make install" I get follogin error:
g++ -frepo -g -O2 -L/usr/local/lib/lib64 -L/usr/lib64/mysql -o zmc zmc.o zm_box.o zm_buffer.o zm_camera.o zm_comms.o zm_config.o zm_coord.o zm.o zm_db.o zm_debug.o zm_event.o zm_exception.o zm_file_camera.o zm_ffmpeg_camera.o zm_image.o zm_jpeg.o zm_local_camera.o zm_monitor.o zm_ffmpeg.o zm_mpeg.o zm_poly.o zm_regexp.o zm_remote_camera.o zm_remote_camera_http.o zm_remote_camera_rtsp.o zm_rtp.o zm_rtp_ctrl.o zm_rtp_data.o zm_rtp_source.o zm_rtsp.o zm_sdp.o zm_signal.o zm_stream.o zm_thread.o zm_time.o zm_timer.o zm_user.o zm_utils.o zm_zone.o -lz -lswscale -lavformat -lavcodec -lavutil -lpcre -lgnutls-openssl -ldl -lpthread -ljpeg -lmysqlclient
zm_sdp.o: In function `SessionDescriptor::generateFormatContext() const':
/usr/src/ZoneMinder-1.24.2/src/zm_sdp.cpp:290: undefined reference to `avformat_alloc_context'
collect2: ld returned 1 exit status
make[1]: *** [zmc] Error 1
make[1]: Leaving directory `/usr/src/ZoneMinder-1.24.2/src'
make: *** [install-recursive] Error 1
Any ideas? It was configured like this:
./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-ffmpeg=/usr/local/lib --with-libarch=lib64
Thanks for all the help!!!
Compiling 1.24.2 on Mandriva
OK, I still haven't figured what is going on.
I'm using latest FFMPEG from www.ffmpeg.org compiled from soruce.
When searching the net/forum for possible answer on
or
Nothing usable shows.
I was using 1.23.3 version earlier (and still use it since this one doesn't copile).
Tried make clean also couple of times, but...
or
Me too
I have the same problem:
zm_sdp.cpp: In member function ‘AVFormatContext* SessionDescriptor::generateFormatContext() const’:
zm_sdp.cpp:290: error: ‘avformat_alloc_context’ was not declared in this scope
zm_sdp.cpp:292: error: ‘strncpy’ was not declared in this scope
And I couldn't continue.
I also found other 2 errors before, but I found these solutions:
http://www.zoneminder.com/forums/viewto ... 55329d368d
http://www.zoneminder.com/forums/viewto ... 4bed92229d
My configure is:
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin --with-webuser=www-data --with-webgroup=www-data --with-libarch=lib64
Debian Lenny, 2.6.26-2-amd64, x86_64, ZM 1.24.2
1.23.3 is fine.
My configure is:
1.23.3 is fine.
