Hi...
I completely rebuilt my server/mythtv/zoneminder box and want to try running zoneminder again on it! But I am having problems installing it:
# dpkg --install zoneminder_1.24.1-1_i386.deb
dpkg: dependency problems prevent configuration of zoneminder:
zoneminder depends on libavcodec52 (>= 3:0.svn20090303-1) | libavcodec-unstripped-52 (>= 3:0.svn20090303-1); however:
Package libavcodec52 is not installed.
Package libavcodec-unstripped-52 is not installed.
I am running Debian stable - I don't think libavcodec52 is available for Debian stable. And I do not want to jeopardize my mythtv set-up by moving to unstable. That took tooooo long to get just right.
Is there a way around this?
-thanks
libavcodec52 problems on debian stable...
I found this:
http://qa.debian.org/debcheck.php?dist= ... zoneminder
...so is this a zoneminder or a Debian problem?
Bump...
I've $100s invested in cameras and have tried zoneminder off and on over the past several years. I have never really considered my set up stable enough to "go it unattended" for any length of time. But I would like to get there this summer as I have a Debian server up and running all the time now.
Does anyone know if this problem I described is a Debian problem, a zoneminder packaging problem or just pilot error on my part?
Thanks for any help.
Usually people on this forum jump in on these types of problems. Any ways, I think this problem is touched upon in this thread. However, it is only mentioned and there is no explanation as to how it was done. So I posted a question there - we'll see...st2000 wrote:Bump...
http://www.zoneminder.com/forums/viewto ... sc&start=0
I have never installed from a package, despite using debian all the time, I always compile the source.
I'm busy updating my live cd (debian based) to the latest version of zoneminder, and have everything working.
A few days ago i installed the latest version of ffmpeg, and libavcodec.so.52 is in the ffmpeg/libavcodec directory.
I think youre probably going to have to do the same, compile from source.
If you mess up, i **think** it's possible to do a uninstall as well.
I do remember having problems compiling ffmpeg, it turned out to be "/usr/lib had old ffmpeg libav* files in it, so delted those and make completed" (taken from my notes on building the cd).
Hope this helps
Hope this helps
