I'm running Ubuntu Hardy Heron 8.04 LTS with a Microsoft VX 1000 Camera.
The camera runs just fine in camorama and cheese, however when I try to set it up for Zoneminder, all I get is a broken image.
Any help?
Broken Images
Then you need to post your log files, all zm files, (check them yourself first, and if there's no obvious errors, incriease the debug level under options). Also your 'messages' , syslog & dmesg files.
If it works under xawtv (whats the output for that) then it's sure to work under zm.
You may also want to look at this thread,
http://www.zoneminder.com/forums/viewto ... sc&start=0
I included it (i think) on my last live CD, it's definitley included on the new one.
