ZM .16 Beta Available
fernando
Re: ZM .16 Beta Available
Post by fernando »
ok i found this error.
ERROR: Date::Manip unable to determine TimeZone.
Date::Manip::Date_TimeZone called at /usr/lib/perl5/vendor_perl/5.6.1/Date/Manip.pm line 629
Date::Manip::Date_Init() called at /usr/lib/perl5/vendor_perl/5.6.1/Date/Manip.pm line 747
Date::Manip::ParseDateString('-8 hour') called at /usr/lib/perl5/vendor_perl/5.6.1/Date/Manip.pm line 1683
Date::Manip::UnixDate('-8 hour', '%s') called at /usr/local/bin/zmfilter.pl line 140
main::strtotime('-8 hour') called at /usr/local/bin/zmfilter.pl line 333
main::GetFilters(2) called at /usr/local/bin/zmfilter.pl line 193
fernando
Post by fernando »
well i set the timezone . cuz i read is a timezone problem.
the problem continues.
zmfilter.pl -m 2
give me that error. if i dont put the command dont work. and dont send any log.
so i dont know.. is the same system i use for 0.15. new instalation.
can anyone tellme if a bug or another thing.
zoneminder
Site Admin
Post by zoneminder »
Hi Fernando,
That's an odd error you have there. Especially as that's not something that has been updated I think. What filters have you got set up on that monitor?
Phil,
fernando
Post by fernando »
Archive status "iqual to" unarchived AND
Date/time "less or iqual to" -8 hour
has you see is a normal setting i have used many times in 0.15 ,,
i has set TZ but was not the problem.
can you tellme if you o Jose has test it and have same error,,
remember i use RH 7.3 and all standard rpms. dont touch any code... yet./.
everything else is working fine.
Fernando
