8port card question
mrq1
8port card question
Post by mrq1 »
hi
a want to buy a 8port pci-card for zoneminder.
after reading the docs/wiki, i know i should get a
card with 8 capture-ICs on it, to get decent framerate.
if there is only one captured input on every chip, i should get the same framerat as with a standalone
PCTV card. is this true?
here is a card with 8x 878A chipset
http://cgi.ebay.de/8-Kanal-240fps-RealT ... dZViewItem
and here one with 8x Philips 7130
are there ony objections on one of this cards?
Lee Sharp
Post by Lee Sharp »
KMay or may not work. There is no way to know without testing. The second one looks like some kodacom clones I have seen, but still no way to know.
brainbug
Post by brainbug »
Lee Sharp wrote:KMay or may not work. There is no way to know without testing. The second one looks like some kodacom clones I have seen, but still no way to know.
Still noone with experience?
Could buy a 4port videocard with 4x philips 7130 chipset from canada for around 40€ (should be around 55$) and that is very very cheap. Normally, we pay around 180-299€ for such a card.
Link: http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... 0373367645 )
Or does anyone know where to buy a card with min. 4 chips and resolution min. 640x480???
Kind regardes,
brainbug
brainbug
Re: I have a card problem
Post by brainbug »
..just supports 320x240 pixels... i want to see 640x480 pixels :-)
But i think i will spend 40€ for a phillips and if it works, i will let all people know that ;-) ...cause i found some helping hints in the ubuntuforums regarding this card.
5th August... got card... installed card... /dev/video0 appeared
no video avaiable :-(
if i attach a camera on port 0 and i choose /dev/video0(0) i can see some strange colors... if i choose /dev/video0(1) i see jsut a blank screen.. think, that zoneminder/v4l recognizes the videocard but i would need some options to be set.
So, does anyone know how and where (somewhere in /etc/modprobe.d/?) to set the options permanently?
Kind regardes,
brainbug
Post by brainbug »
So.. meanwhile, i got a solution :-)
Just added /etc/modprobe.d/saa7134.conf
options saa7134 card=60,60,60,60
and i got 4 cams working under xawtv with realtime-framerate with 640x480 pixels ;-)
Tomorrow, i will try it with Zoneminder (cause i crashed my system a little bit and i am not able to reinstall it completley) and if it works, i will place a description of this card with picture and details inside the "supported hardware list" ...or someone else could do that :-)
sorry again for my crazy english ;-)
25th September 2009
Zoneminder is running with 4 cams and in relatime-framerate with 640x480 resolution :-)
