I am seeing some events with a timestamp of 1969-12-31.
This seems to only happen on my newer builds using Ubuntu. I used to standardize on CentOS but have since made the switch to Ubuntu.
Running Ubuntu Server 9.04 amd64 (seeing this on 32bit boxes also)
Zoneminder built according to this guide:
http://www.zoneminder.com/forums/viewtopic.php?t=14281
I noticed that normando and cordel were troubleshooting this at the beginning of the year in 1.23.x:
http://www.zoneminder.com/forums/viewto ... light=1969
zmf is disabled and this is still happening.
Like normando, I verified that these timestamps are being written to the database with the 1969 timestamp.
I have not configured any php TZ yet.
Can anybody point me in the right direction?
1969-12-31 Event Timestamps
I think that I resolved the timestamp issues by doing the following:
FIRST INSTALL mysqltuner:
sudo -i
apt-get install mysqltuner
STOP ZONEMINDER
/etc/init.d/zm stop
STOP MYSQL
/etc/init.d/mysql stop
EDIT YOUR my.cnf FILE
vi /etc/mysql/my.cnf
UNCOMMENT skip-innodb OR ADD IT IF IT IS NOT IN THERE
MAKE SURE THE THE FOLLOWING PARAMETERS ARE SET:
key_buffer = 16M
max_allowed_packet = 32M
thread_stack = 128K
thread_cache_size = 8
query_cache_limit = 1M
query_cache_size = 24M
ADD THESE PARAMETERS:
tmp_table_size = 32M
max_heap_table_size = 16M
SAVE AND EXIT
START MYSQL
/etc/init.d/mysql start
START ZONEMINDER
/etc/init.d/zm start
IF YOU WANT TO TUNE YOUR OWN SYSTEM, LET YOUR SYSTEM RUN NORMALLY FOR ABOUT 15 MINUTES AND THEN RUN:
mysqltuner
IT WILL ASK YOU FOR YOUR MYSQL ROOT USERNAME AND PASSWORD SO ENTER IT
ONCE YOU ENTER YOUR USERNAME AND PASSWORD IT WILL GIVE YOU SOME RECOMMENDATIONS. I WOULD GUESS THAT IF YOU APPLY THE ABOVE SETTINGS IT WILL NOT RECOMMEND ANY CHANGES.
You can disregard this:
General recommendations:
Enable the slow query log to troubleshoot bad queries
You will probably find that your system will run with greater efficiency
sudo -i
STOP ZONEMINDER
/etc/init.d/zm stop
STOP MYSQL
key_buffer = 16M
thread_stack = 128K
SAVE AND EXIT
START MYSQL
START ZONEMINDER
mysqltuner
Thanks for the tips
I have Zm 1.22.3 under mandriva 2007 from livecd. I use to consider the performance to be excellent but tried mysqltuner just to see what happends and now i and getting even better performance.
This might be something every one should try. Just make a copy of your my.cnf in case you want to return to original settings.
I was worried about installation of mysqltunner but finally discovered that is a script that you download (no need to install) .
All i had to do was.
wget -O mysqltuner.pl http://tools.assembla.com/mysqltuner/br ... format=txt
chmod 775 mysqltuner.pl
To run it just go to the palce you have it and type
perl mysqltuner.pl
This is someting i has never done before and there are some recommendations that i have to read more about. I have just applied the ones you mentioned and i can see a increase in performance,
perl mysqltuner.pl
