I have link like: rtsp://admin:admin@x.x.x.x/live/mpeg4 - and it's work in browser, VLC & etc.
Trying to add, use all four methods of RTSP - nothing work.
tail of log:
09/11/09 12:10:53.038231 zmc_m10[-1].DB1-zm_monitor.cpp/2262 [Got 1 monitors]
09/11/09 12:10:53.038531 zmc_m10[-1].DB1-zm_thread.cpp/241 [Creating thread]
09/11/09 12:10:53.038569 zmc_m10[-1].DB2-zm_rtsp.cpp/187 [RTSP Local SSRC is 354a093e]
09/11/09 12:10:53.038577 zmc_m10[-1].DB1-zm_thread.cpp/280 [Starting thread]
09/11/09 12:10:53.038681 zmc_m10[-1].DB2-zm_thread.cpp/253 [Invoking thread]
09/11/09 12:10:53.069164 zmc_m10[-1].DB2-zm_rtsp.cpp/46 [Sending RTSP message: DESCRIBE rtsp://10.110.6.28:554/live/mpeg4 RTSP/1.0
Authorization: Basic YWRtaW46YWRtaW4=
User-Agent: ZoneMinder/1.24.2
CSeq: 1
09/11/09 12:10:53.069438 zmc_m10[-1].DB1-zm_thread.cpp/301 [Started thread -1]
09/11/09 12:10:53.080515 zmc_m10[-1].DB1-zm_monitor.cpp/338 [monitor purpose=1]
09/11/09 12:10:53.080556 zmc_m10[-1].DB1-zm_monitor.cpp/345 [mem.size=48662004]
09/11/09 12:10:53.286649 zmc_m10[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 704x576 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
09/11/09 12:10:53.292910 zmc_m10[-1].DB1-zm_monitor.cpp/458 [Monitor 10 has function 2]
09/11/09 12:10:53.292970 zmc_m10[-1].DB1-zm_monitor.cpp/459 [Monitor 10 LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
09/11/09 12:10:53.292978 zmc_m10[-1].DB1-zm_monitor.cpp/460 [Monitor 10 IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
09/11/09 12:10:53.293128 zmc_m10[-1].DB1-zm_zone.cpp/889 [Got 1 zones for monitor 10]
09/11/09 12:10:53.293140 zmc_m10[-1].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 703,0 703,575 0,575']
09/11/09 12:10:53.293146 zmc_m10[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
09/11/09 12:10:53.293152 zmc_m10[-1].DB3-zm_zone.cpp/796 [Got coordinate 703,0 from polygon string]
09/11/09 12:10:53.293157 zmc_m10[-1].DB3-zm_zone.cpp/796 [Got coordinate 703,575 from polygon string]
09/11/09 12:10:53.293161 zmc_m10[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,575 from polygon string]
09/11/09 12:10:53.293169 zmc_m10[-1].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
09/11/09 12:10:53.293176 zmc_m10[-1].DB1-zm_zone.cpp/50 [Initialised zone 10/All - 1 - 704x576 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:12165, MxAP:304128, FB:3x3, MnFP:12165, MxFP:304128, MnBS:8110, MxBS:0, MnB:1, MxB:0, OF: 0]
09/11/09 12:10:53.385226 zmc_m10[-1].DB1-zm_monitor.cpp/2459 [Loaded monitor 10(10), 1 zones]
09/11/09 12:10:53.385261 zmc_m10[-1].INF-zmc.cpp/188 [Starting Capture]
09/11/09 12:10:53.385420 zmc_m10[-1].DB2-zm_remote_camera_rtsp.cpp/112 [Waiting for sources]
09/11/09 12:10:54.069375 zmc_m10[-1].DB2-zm_rtsp.cpp/72 [Received RTSP response: RTSP/1.0 200 OK
CSeq: 1
Content-Base: rtsp://10.110.6.28:554/live/mpeg4/
Content-Type: application/sdp
Content-Length: 225
v=0
o=- 1 1 IN IP4 127.0.0.1
s=Test
a=type:broadcast
t=0 0
c=IN IP4 0.0.0.0
m=video 0 RTP/AVP 96
a=rtpmap:96 MP4V-ES/90000
a=fmtp:96 profile-level-id=3;config=00000100000001200086C4007B0C581120518F
a=control:track0
(355 bytes)]
09/11/09 12:10:54.069485 zmc_m10[-1].DB1-zm_rtsp.cpp/304 [Processing SDP 'v=0
s=Test
a=type:broadcast
t=0 0
c=IN IP4 0.0.0.0
a=control:track0
09/11/09 12:10:54.069533 zmc_m10[-1].DB3-zm_sdp.cpp/126 [Processing SDP line 'v=0']
09/11/09 12:10:54.069556 zmc_m10[-1].DB3-zm_sdp.cpp/126 [Processing SDP line 'o=- 1 1 IN IP4 127.0.0.1']
09/11/09 12:10:54.069568 zmc_m10[-1].DB3-zm_sdp.cpp/126 [Processing SDP line 's=Test']
09/11/09 12:10:54.069574 zmc_m10[-1].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=type:broadcast']
09/11/09 12:10:54.069595 zmc_m10[-1].DB3-zm_sdp.cpp/259 [Ignoring general SDP attribute 'type:broadcast']
09/11/09 12:10:54.069602 zmc_m10[-1].DB3-zm_sdp.cpp/126 [Processing SDP line 't=0 0']
09/11/09 12:10:54.069608 zmc_m10[-1].DB3-zm_sdp.cpp/126 [Processing SDP line 'c=IN IP4 0.0.0.0']
09/11/09 12:10:54.069743 zmc_m10[-1].DB3-zm_sdp.cpp/126 [Processing SDP line 'm=video 0 RTP/AVP 96']
09/11/09 12:10:54.069762 zmc_m10[-1].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=rtpmap:96 MP4V-ES/90000']
09/11/09 12:10:54.069774 zmc_m10[-1].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=fmtp:96 profile-level-id=3;config=00000100000001200086C4007B0C581120518F']
09/11/09 12:10:54.069792 zmc_m10[-1].DB3-zm_sdp.cpp/126 [Processing SDP line 'a=control:track0']
09/11/09 12:10:54.070118 zmc_m10[-1].DB1-zm_sdp.cpp/305 [Looking for codec for video payload type 96 / MP4V-ES]
09/11/09 12:10:54.070131 zmc_m10[-1].DB1-zm_sdp.cpp/334 [Got dynamic payload type 96, MP4V-ES]
09/11/09 12:10:54.070145 zmc_m10[-1].DB2-zm_rtsp.cpp/46 [Sending RTSP message: SETUP rtsp://10.110.6.28:554/live/mpeg4/track0 RTSP/1.0
Transport: RTP/AVP/TCP;unicast
CSeq: 2
09/11/09 12:10:54.285279 zmc_m10[-1].DB2-zm_rtsp.cpp/72 [Received RTSP response: RTSP/1.0 200 OK
CSeq: 2
Transport: RTP/AVP/TCP;unicast;interleaved=0-1
Session: 471A30A869D18F809F9FF95E4B73E4
(117 bytes)]
09/11/09 12:10:54.285427 zmc_m10[-1].DB2-zm_rtsp.cpp/396 [Got RTSP session 471A30A869D18F809F9FF95E4B73E4, timeout 0 secs]
09/11/09 12:10:54.285440 zmc_m10[-1].DB2-zm_rtsp.cpp/401 [Got RTSP transport RTP/AVP/TCP;unicast;interleaved=0-1]
09/11/09 12:10:54.285486 zmc_m10[-1].DB2-zm_rtsp.cpp/449 [RTSP Method is RTP/RTSP]
09/11/09 12:10:54.285492 zmc_m10[-1].DB2-zm_rtsp.cpp/450 [RTSP Distribution is unicast]
09/11/09 12:10:54.285496 zmc_m10[-1].DB2-zm_rtsp.cpp/451 [RTSP SSRC is 0]
09/11/09 12:10:54.285501 zmc_m10[-1].DB2-zm_rtsp.cpp/452 [RTSP Local Host is ]
09/11/09 12:10:54.285505 zmc_m10[-1].DB2-zm_rtsp.cpp/453 [RTSP Local Ports are 0/0]
09/11/09 12:10:54.285510 zmc_m10[-1].DB2-zm_rtsp.cpp/454 [RTSP Remote Ports are 0/0]
09/11/09 12:10:54.285514 zmc_m10[-1].DB2-zm_rtsp.cpp/455 [RTSP Remote Channels are 0/1]
09/11/09 12:10:54.285528 zmc_m10[-1].DB2-zm_rtsp.cpp/46 [Sending RTSP message: PLAY rtsp://10.110.6.28:554/live/mpeg4 RTSP/1.0
Range: npt=0.000-
CSeq: 3
09/11/09 12:10:54.291837 zmc_m10[-1].DB2-zm_rtsp.cpp/72 [Received RTSP response: RTSP/1.0 200 OK
CSeq: 3
(69 bytes)]
09/11/09 12:10:54.292025 zmc_m10[-1].FAT-zm_rtsp.cpp/471 [Unable to get RTP Info identifier from response 'RTSP/1.0 200 OK
CSeq: 3
09/11/09 12:10:54.292347 zmc_m10[-1].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
09/11/09 12:10:54.292375 zmc_m10[-1].ERR-zm_signal.cpp/90 [Signal address is 0x206, no eip]
09/11/09 12:10:54.292665 zmc_m10[-1].ERR-zm_signal.cpp/122 [Backtrace: /lib/libpthread.so.0 [0x7f7372c8a080]]
09/11/09 12:10:54.292681 zmc_m10[-1].ERR-zm_signal.cpp/122 [Backtrace: /lib/libc.so.6(gsignal+0x35) [0x7f7371b6ffb5]]
09/11/09 12:10:54.292692 zmc_m10[-1].ERR-zm_signal.cpp/122 [Backtrace: /lib/libc.so.6(abort+0x183) [0x7f7371b71bc3]]
09/11/09 12:10:54.292702 zmc_m10[-1].ERR-zm_signal.cpp/122 [Backtrace: /usr/bin/zmc [0x40f3f0]]
09/11/09 12:10:54.292713 zmc_m10[-1].ERR-zm_signal.cpp/122 [Backtrace: /usr/bin/zmc [0x440ff2]]
09/11/09 12:10:54.292724 zmc_m10[-1].ERR-zm_signal.cpp/122 [Backtrace: /usr/bin/zmc [0x44ba15]]
09/11/09 12:10:54.292734 zmc_m10[-1].ERR-zm_signal.cpp/122 [Backtrace: /lib/libpthread.so.0 [0x7f7372c823ba]]
09/11/09 12:10:54.292744 zmc_m10[-1].ERR-zm_signal.cpp/122 [Backtrace: /lib/libc.so.6(clone+0x6d) [0x7f7371c22fcd]]
09/11/09 12:10:54.292755 zmc_m10[-1].INF-zm_signal.cpp/125 [Backtrace complete, please execute the following command for more information]
09/11/09 12:10:54.292975 zmc_m10[-1].INF-zm_signal.cpp/126 [addr2line -e /lib/libc.so.6(clone+0x6d) 0x7f7372c8a080 0x7f7371b6ffb5 0x7f7371b71bc3 0x40f3f0 0x440ff2 0x44ba15 0x7f7372c823ba 0x7f7371c22fcd]
