2 Cams (Same Models), 1 has image, 1 does not.
mrme
Post by mrme »
I have 2 cams right now. Model WVC2300.
I have one (cam-1) working great. Zones and All. It is set to modetect.
I setup cam-2 the exact same way, but diff ip address and name. Its set to monitor. The source is orange. No live feed. I set it to modetect to test, and it did capture an image.
But when i view the live feed, its just blank. It will even show a framerate and says its state is idle.
Really pulling my hair out on this one. Its on a CentOS 5 box. Let me know what other info you need from me.
mrme
Post by mrme »
Nevermind, i got it. Changed it from mpeg to jpeg
warder
Post by warder »
what settings are you using in zm and in the camera?
we have a couple pvc2300's which should be the same as yours, except they are not wireless.
we cant get any image from the cameras inside zm.
otherwise they work from http, or from the linksys camera utility.
