hello,
Does ZoneMinder support 64bit ? Can i run it on a 64bit (freeBSD) ?
Also I got PCIE slots, not PCI, any support for PCIE (i guess shouldn't differ, as long as OS supports it? ) but will some PCIE cards work to hook up the cameras?
thank you
64bit
64-bit
I had it running on 64bit Ubuntu but it crashed A LOT... However there may have been some other issues. Your milage may vary.
hello,
I've run ubuntu servers and desktops. It crashes a lot, i wouldn't recommend it for more advanced stuff.
I just realised that zoneminder is mostly script software(right?) so it will run on 64bit like a jet fighter
I just need to know how about PCIexpress slots? are there any cards that will work? Then i can start everything.
Thank you!!
Thank you!!
- knight-of-ni
