Is it normal that when i delete events in the browser, that these events are not deleted on disk ?
grtz, Ph.
deleted events not deleted from disk
It is normal when you have OPT_FAST_DELETE under the system options checked.
OPT_FAST_DELETE tell's zoneminder to simply delete the database records of an event when you delete them in the WebUI. The ZMAUDIT daemon in the background will periodically check for event folders of events that have been deleted and delete them.
You should see the events deleted off the disk eventually.
