Hi there,
I have been trying to get an example perl monitor script working which I have had working on previous versions of zoneminder. On ZM 1.24.1 it seems to throw up the folowing error:-
Undefined subroutine &main::zmShmVerify
Knowing little about perl I can't sus the problem, At a guess the subroutine no longer exists or maybe shared memory is not being used. Can someone help diagnose or help with an equivalent script for 1.24.1
The perl script used is as follows:-
#!/usr/bin/perl -w
use strict;
use ZoneMinder;
$| = 1;
my $sql = "select M.*, max(E.Id) as LastEventId from Monitors as M left join Events as E on M.Id = E.MonitorId where M.Function != 'None' group by (M.Id)";
my @monitors;
push( @monitors, $monitor );
while( 1 )
next if ( !zmShmVerify( $monitor ) );
# Do your stuff here
sleep( 1 );
Undefined subroutine &main::zmShmVerify called at /root/sms/zm-trigger.pl line 27
Many thanks,
John
ZoneMinder to trigger script
