Where is ZM_WEB_MONTAGE in 1.24.x?
kp4djt
Post by kp4djt »
I have searched on it and find nothing, but when I go to options>web I no longer find ZM_WEB_MONTAGE, I would like to have the montage open at 1/2 screen size so all of the images fit on the screen, I recall that I had set
it in 1.23.3 and it opened the screens at the right size, but now I can not find it so every time I open montage I have to go in and set the scale manually. Is the moved elsewhere or am I missing something?
Chuck Hast -- KP4DJT --
Web site www.wchast.com
ZM demo www.wchast.com/zm
DREMA
Post by DREMA »
You can set the deafault scale, rate and view on the "Misc" tab on the settings of every camera.
zoneminder
Site Admin
Post by zoneminder »
If you go to the montage page and select the scaled layout then it will fit your cameras to whatever size you change the page to.
Phil
kp4djt
Post by kp4djt »
DREMA wrote:You can set the deafault scale, rate and view on the "Misc" tab on the settings of every camera.
I tried that it only works with the console view of the camera not in the Montage view at least on my system.
kp4djt
Post by kp4djt »
zoneminder wrote:If you go to the montage page and select the scaled layout then it will fit your cameras to whatever size you change the page to.
Thank you! that is exactly what I was looking for. I do wish that the scale could be made sticky though. but that did the trick.
Is that one not in the documents?? I did a search and found nothing.
