Trendnet TV-IP501P
lviper
Trendnet TV-IP501P
Post by lviper »
I got the Trendnet TV-IP501P working with the following settings:
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: user:pass@x.x.x.x (admin:admin is the default user/pass and 192.168.0.30 is the default IP)
Remote Host Port: 80
Remote Host Path: /mjpeg.cgi
using 320x240 on medium in the camera's settings.
smaclean
help with tv-ip501p
Post by smaclean »
I have zoneminder v1.22.3 installed on ubuntu 8.04 server, I have the settings configured as you have listed. In the console view, it shows my monitor Name/Function/Source highlighted in green which I assume means it's detected and configured properly. When I click on the name to view the camera, I get no video or image.
What version of zoneminder do you have installed? I don't see a setting for method simple and protocol http anywhere in my zoneminder config options.
lviper
Post by lviper »
I'm using version 1.24.2
freak
Post by freak »
Got this cam working too on 1.23.3. Nice inexpensive poe cam.
psmith44
Post by psmith44 »
Has anyone gotten this camera to work using 640x480? When I try and set it up to, the image is mysteriously blank...yet when using 320x240, it works perfectly.
freak
Post by freak »
Yep. I'm running 640x480 color. You probably need to change the memory settings in zm.
