Error 255 amongst other things
Fitch
Post by Fitch »
Latest try on Zoneminder 1.23
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for a BSD-compatible install... /usr/bin/install -c
checking whether make sets $(MAKE)... (cached) yes
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for size_t... yes
checking return type of signal handlers... void
checking for siginfo_t... yes
checking for struct sigcontext... yes
checking for struct sigcontext.eip... yes
checking for ucontext_t... yes
checking how to run the C++ preprocessor... g++ -E
checking mysql/mysql.h usability... yes
checking mysql/mysql.h presence... yes
checking for mysql/mysql.h... yes
checking pcre/pcre.h usability... no
checking pcre/pcre.h presence... no
checking for pcre/pcre.h... no
checking pcre.h usability... yes
checking pcre.h presence... yes
checking for pcre.h... yes
checking whether round is declared... yes
checking whether strsignal is declared... yes
checking whether MD5 is declared... yes
checking whether backtrace is declared... yes
checking for jpeg_start_compress in -ljpeg... no
configure: error: zm requires libjpeg.a
Where does that come from?
Fitch
Post by Fitch »
OK.
I downloaded and installed PHP
Then I downloaded and installed libjpeg7
Then I did:
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin --with-webuser=www-data --with-webgroup=www-data
and it actually said:
"looks good"
So I did:
make install ZoneMinder
and then the thing came up with hundreds of lines and ended as shown below:
make[3]: Entering directory `/root/Downloads/ZoneMinder'
( cd /usr/local/etc; chown www-data:www-data zm.conf; chmod 600 zm.conf )
( if ! test -e /var/run; then mkdir /var/run; fi )
( if ! test -e /var/run/zm; then mkdir /var/run/zm; fi; chown www-data:www-data /var/run/zm; chmod u+w /var/run/zm )
make[3]: Leaving directory `/root/Downloads/ZoneMinder'
make[2]: Leaving directory `/root/Downloads/ZoneMinder'
make[1]: Leaving directory `/root/Downloads/ZoneMinder'
make: *** No rule to make target `ZoneMinder'. Stop.
Is this good or bad?
littlej
Post by littlej »
afther config do :
"make"
if this goes well
do :
"make install"
gl
Fitch
Post by Fitch »
The ./config seemed to go very well
The make seemed to go O.K. It said it was leaving the directories and then finished.
this is the last load of lines after the make install:
Appending installation info to /usr/local/lib/perl/5.10.0/perllocal.pod
make[2]: Leaving directory `/root/Downloads/ZoneMinder/scripts/ZoneMinder'
make[1]: Leaving directory `/root/Downloads/ZoneMinder/scripts'
Making install in db
make[1]: Entering directory `/root/Downloads/ZoneMinder/db'
make[2]: Entering directory `/root/Downloads/ZoneMinder/db'
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/root/Downloads/ZoneMinder/db'
make[1]: Leaving directory `/root/Downloads/ZoneMinder/db'
make[1]: Entering directory `/root/Downloads/ZoneMinder'
make[2]: Entering directory `/root/Downloads/ZoneMinder'
test -z "/usr/local/etc" || /bin/mkdir -p "/usr/local/etc"
/usr/bin/install -c -m 644 'zm.conf' '/usr/local/etc/zm.conf'
make install-data-hook
root@Cameras:~/Downloads/ZoneMinder#
Is this good?
littlej
Post by littlej »
yea it seems to be ok
Fitch
Post by Fitch »
Great!!
But,sorry to be a pain, but shouldn't it come up on one of the menus? e.g. Applications/Sound & Video/ZoneMinder, or am I just being naive (Sorry, extreme newbie here, Installed Linux about a week ago)
Fitch
Post by Fitch »
After perusing through the wiki page for Ubuntu, and doing the path change as directed in:
http://www.zoneminder.com/wiki/index.ph ... _interface
I opened the web page http://localhost as instructed and got:
Warning: mysql_pconnect() [function.mysql-pconnect]: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) in /usr/share/zoneminder/includes/database.php on line 32
Could not connect to database: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
Again as per 7 posts ago (last post on page 1), this directory is empty,
I've eaten the sausages
Nada
Zilch
etc.
B*gg*r!
littlej
Post by littlej »
do you have mysql instaled ?
Fitch
Post by Fitch »
Mysql administrator and mysql query browser both come up under Applications/Programming and mysql Navigator comes up under Accessories.
The Ubuntu Software Centre also confirms that I have Mysql Client and Mysql Server installed.
But when I open a terminal and type it in, I get the following:
root@Cameras:~# mysql
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
root@Cameras:~# ^C
or
root@Cameras:~# mysql mysql
or even
root@Cameras:~# mysql < db/zm_create.sql
bash: db/zm_create.sql: No such file or directory
If I change directory to /Downloads/ZoneMinder and try the last command:
root@Cameras:/# cd ./usr/share/zoneminder/
root@Cameras:/usr/share/zoneminder# mysql < db/zm_create.sql
so, obviously, I haven't done something..
Now if I go into mysql administrator, everything is greyed out, except for the "Add", so is it just a case of sticking something in there?
Is it simply a case of loading mysql, and if so from where? or is there something else I have missed?
littlej
Post by littlej »
try : apt-get install mysql
if i remember coreclty this apt-get its in ubuntu,
that way it will install mysql server i hope :P
afther that startup scripts should be in /etc/init.d/
so u should start it up like this :
/etc/init.d/mysqld start or restart
afther that user mysql and if u got a mysql promt than u have mysql runing
gl
Fitch
Post by Fitch »
Tried that a while back, never worked!
But...
After downloading from http://dev.mysql.com/downloads/mysql/5.1.html#source
then going to http://tantos.web.id/blogs/installing-a ... buntu-9-04
doing what it says until the configure bit - which is missing the last bit, finding the last bit from another website to get the code below,
./configure --prefix=/usr/local/mysql --with-mysqld-user=mysql --without-debug --with-client-ldflags=-all-static --with-mysqld-ldflags=-all-static --disable-shared --localstatedir=/usr/local/mysql/data --with-extra-charsets=none --enable-assembler --with-unix-socket-path=/tmp/mysql.socket --with-named-curses-libs=/usr/lib/libncurses.a
Then I had to get libncurses5-dev, .configure all over again.
make
make install
Doing the rest of http://tantos.web.id/blogs/installing-a ... buntu-9-04
Only to get
/etc/init.d/mysql start
Starting MySQL
... * Manager of pid-file quit without updating file.
root@Cameras:~/Downloads/mysql-5.1.40# mysql_install_db
Installing MySQL system tables...
091107 17:29:25 [ERROR] /usr/sbin/mysqld: unknown option '--if ($CMD) {'
091107 17:29:25 [ERROR] Aborting
091107 17:29:25 [Warning] Forcing shutdown of 2 plugins
091107 17:29:25 [Note] /usr/sbin/mysqld: Shutdown complete
Fitch
Post by Fitch »
I've had a look at the my.cnf file as per http://www.directadmin.com/forum/showpo ... stcount=33
and found about 6 lines that all had /var/run/mysql instead of /var/lib/mysql
so I changed that and now I get
mysqld
091107 21:32:41 [Warning] options --log-slow-admin-statements, --log-queries-not-using-indexes and --log-slow-slave-statements have no effect if --log_slow_queries is not set
091107 21:32:41 [Note] Plugin 'FEDERATED' is disabled.
091107 21:32:41 InnoDB: Started; log sequence number 0 44233
091107 21:32:41 [ERROR] Can't start server : Bind on unix socket: Permission denied
091107 21:32:41 [ERROR] Do you already have another mysqld server running on socket: /var/lib/mysqld/mysqld.sock ?
091107 21:32:41 [ERROR] Aborting
091107 21:32:41 InnoDB: Starting shutdown...
091107 21:32:43 InnoDB: Shutdown completed; log sequence number 0 44233
091107 21:32:43 [Warning] Forcing shutdown of 1 plugins
091107 21:32:43 [Note] mysqld: Shutdown complete
Am I going forwards or backwards?
Am I talking to myself again?
Fitch
Post by Fitch »
Forget it.
I just wiped the hard drive and loaded Ubuntu 9 and Zoneminder 23.
fernandoc
Reinstall
Post by fernandoc »
Hola,
I had the same problem, I solved using synaptic doing a complete uninstall (purge), I guess should be the same from terminal.
Happy New Year
Fernandoc
whatboy
Post by whatboy »
What does sudo service mysqld status give you???
if it stoped runnit /etc/init.d/mysqld start
what does sudo chkconfig mysqld --list gives you???
if all off then chkconfig --level 345 mysqld on
