Upgrading 1.24.1 to 1.24.2
crates
Post by crates »
I installed ZM from the ubuntu repository which is only 1.24.1.
I'd like to upgrade this to 1.24.2 but I'm not sure what to do :?
There is a 1.24.2 DEB file available but if I just install it, does it upgrade everything (e.g. the database) or would I need to run something manually ?
Also, does it address the issue where apache is hanging due to sockets being left open by certain browsers ?
I'd like to upgrade but don't want to break my box trying !
Thanks guys
kingofkya
Post by kingofkya »
every thing should be good including the database it will be automatically updated.
if it dosen't all you have to run is zmupdate.pl
crates
Post by crates »
Thank you, you're a star
I'll give it a blast over the weekend.
crates
Post by crates »
It seems to have worked :D
Thanks for the help
