Install guide for ZONEMINDER over DEBIAN LENNY - SPANISH -
rockmanchile
Post by rockmanchile »
Hi all.
I want to share with the comunity a liitle guide that i made to succesfully install a ZM Server over a Debian Lenny based machine.
The guide is in spanish, but the Linux language is universal !
I will make an english copy soon.
Hope you enjoy it!
rockmanchile
http://www.zenner.cl/Instalacion%20de%2 ... 0Lenny.pdf
mac86
Post by mac86 »
very good post!
thank you!
rockmanchile
thanks !
ryderzm
Excellent post
Post by ryderzm »
outstanding work.. the google translation was spot on. you rock!!
rockmanchile
:D
nicocam
Post by nicocam »
Hola rockmanchile,
No tuviste problemas para exportar el video? Probaste el sistema con alguna camara ip?
Gracias
Debian User
rockmanchile
no tuve ningun problema con las exportaciones, aunque no he probado aun con camaras IP.
Asumo que debe ser lo mismo por que la exportacion se hace a partir del evento que registra la camara, o sea, convierte los JPEG del evento a video.
Si pruebas dejanoslo saber!
Saludos.
Rockmanchile.
rockmanchile
i just upload the guide in the wiki if any of you want to check it out:
http://www.zoneminder.com/wiki/index.php/Debian
cheers.
rockmanchile.
kenspank
Post by kenspank »
I read Spanish well enough to understand your directions. It worked very well.
gracias!
Now all I have to do is get the config settings right for this camera (vivotek ip7131)
rockmanchile
thanks ;)
