I followed the ZM installation guide on Ubuntu 9.04 server 32 bit. But the compilation
failed and "make" returned 2 errors in the "Install & Config zoneminder" section. If you
had a successful zm install on Ubuntu 9.10 server 32 bit please help with how
you were able to get it done. If you followed this procedure what changes did you make?
http://www.zoneminder.com/wiki/index.ph ... rver_32bit
Any one with zm on Ubuntu 9.10 server 32 bit ?
I have success install from here http://www.zoneminder.com/forums/viewtopic.php?t=14783
Re: Any one with zm on Ubuntu 9.10 server 32 bit ?
What is the message error?yosepht wrote:I followed the ZM installation guide on Ubuntu 9.04 server 32 bit. But the compilation
failed and "make" returned 2 errors in the "Install & Config zoneminder" section. (
Here are a few of the lines from make. I couldn't cut and paste from a server terminal on
another computer.
zm_utitls.cpp:32: error: 'vsprintf" was not declared in this scope
zm_utils.cpp:47: error: "vsprintf" was not declared in this scope
make[2]: *** [zm_utils.o] error1
make[2]: leaving directory 'usr/src/zm/src
make[2]: *** [all_recursive] error1
make: *** [all] error 2
Thanks for taking the time. Yoseph.
another computer.
Try this:yosepht wrote:Here are a few of the lines from make. I couldn't cut and paste from a server terminal on
another computer.
Edit the file: ZoneMinder-1.24.2/src/zm_utils.cpp and, after the second line, add the following:
+#include <stdio>
Note:Sidon wrote:Code: Select all
+#include <stdio>
After the word 'stdio' there is a dot and one caracter "h", which are missing after submit.
stdio.h
