I have a strange issue with Zoneminder. I am running Zoneminder V1.24.1 on Debian Lenny on an AMD Athlon(TM) XP 2100+ with 1Gb ram. I am using a single BT878 card (card=77) with 2 cameras attached connected to channels 0 and 1, both set to MoDect.
All appears to be fine - I can see video from both cameras clearly. However, when someone walks in front of the cameras or other movement is apparent (by looking at the feed), no events are captured. Its quite obvious movement too, not just in the corner of the FOV, but right slap bang in the middle, large as life.
I have added a symlink from events to /home/zoneminder/events and images to /home/zoneminder/images (there's more space on that partition). However I'd have thought that if this was the problem, then the events would fire but you would not be able to see the images (I did this before on V1.23.x. I incorrectly set the paths, and it did indeed capture events but you could not see them). So I am a little unsure as to what is going on.
Any help you can give would be appreciated.
