cameras are showing others video
ej
Post by ej »
Using Zoneminder v1.24.2
Capture card,
[ 97.424131] bttv0: detected: Provideo PV143A [card=105], PCI subsystem ID is aa00:1430
[ 97.424142] bttv0: using: ProVideo PV143 [card=105,autodetected]
OS,
2.6.30-2-486 - Debain
Using /dev/video0 on channels 3, 2, and 1
Video for linux 1, and NTSC
I have 3 analog cameras.
When viewing them in monitoring mode, or looking at the recorded video I get the other cameras images mixed in with it split horizontally and "bouncy" . It will either cut between 2 of them pretty fast or display one camera on top, then another on the bottom. It moves around, and isn't consistent.
Some recent logs,
Nov 30 11:39:24 nest zma_m3[6769]: INF [outdoor-2: 7000 - Processing at 8.62 fps]
Nov 30 11:39:24 nest zma_m2[6632]: INF [ourdoor-1: 15000 - Processing at 8.62 fps]
Nov 30 11:40:00 nest zma_m3[6769]: INF [outdoor-2: 7307 - Closing event 82, section end]
Nov 30 11:40:00 nest zma_m2[6632]: INF [ourdoor-1: 15303 - Closing event 83, section end]
Nov 30 11:40:00 nest zma_m2[6632]: INF [ourdoor-1: 15303 - Opening new event 85, section start]
Nov 30 11:40:00 nest zma_m3[6769]: INF [outdoor-2: 7307 - Opening new event 84, section start]
Nov 30 11:40:09 nest zmc_dvideo0[6755]: INF [outdoor-2: 8000 - Capturing at 8.55 fps]
Nov 30 11:40:09 nest zmc_dvideo0[6755]: INF [ourdoor-1: 8000 - Capturing at 8.55 fps]
Nov 30 11:40:09 nest zmdc[2594]: INF [Starting pending process, zmc -d /dev/video]
Nov 30 11:40:09 nest zmdc[2594]: INF ['zmc -d /dev/video' starting at 09/11/30 11:40:09, pid = 6824]
Nov 30 11:40:09 nest zmc_dvideo0[6755]: INF [Dome: 8000 - Capturing at 8.55 fps]
Nov 30 11:40:09 nest zmdc[6824]: INF ['zmc -d /dev/video' started at 09/11/30 11:40:09]
Nov 30 11:40:10 nest zmc_dvideo[6824]: INF [Debug Level = 0, Debug Log = <none>]
Nov 30 11:40:10 nest zmc_dvideo[6824]: ERR [No monitors found]
Nov 30 11:40:10 nest zmdc[2594]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Nov 30 11:40:19 nest zma_m1[6712]: INF [Dome: 12000 - Processing at 8.55 fps]
Nov 30 11:40:44 nest zms[6826]: INF [Debug Level = 0, Debug Log = <none>]
Nov 30 11:40:48 nest zms[6826]: INF [Got signal 15 (Terminated), exiting]
Nov 30 11:40:51 nest zms[6827]: INF [Debug Level = 0, Debug Log = <none>]
Nov 30 11:40:54 nest zms[6827]: INF [Got signal 15 (Terminated), exiting]
Nov 30 11:40:57 nest zms[6828]: INF [Debug Level = 0, Debug Log = <none>]
Nov 30 11:41:05 nest zms[6828]: INF [Got signal 15 (Terminated), exiting]
Nov 30 11:41:20 nest zma_m3[6769]: INF [outdoor-2: 8000 - Processing at 8.62 fps]
Nov 30 11:41:21 nest zma_m2[6632]: INF [ourdoor-1: 16000 - Processing at 8.55 fps]
ej
Post by ej »
Just checked in xawtv, and am getting similar display issues.
ej
Post by ej »
figured it out,
unchecked, "V4L_MULTI_BUFFER" in the options, and restarted zoneminder.
Looks good now.
