Hi, i'll still tring to resolve a problem with my pci dvr 8 channel card. Sometimes i get I/O error like the input is unplegged.
I run 2 cameras at 640x480 in 24bit rgb. At 10fps each zmc crash randomly. A 6 fps is stable. So i think to a some kind of memory issue (not reletad to sysctl parameters like shmmax and shmall after the thousand of attemps i've done)
So i started to search to another problem location.... and i have tought to the pci bus.
So, with some calc it result a 122mb consuption of ram from the cams. And with only 2 card! What happen if i attach another cam? The pci bus 33mhz doesnt have only 133MB/sec of bandwidth??
PCI bandwidth
You aren't even close to saturate the PCI bus.
640x480 24bit at 10fps is a 8.78 MB/s stream when uncompressed.
So for two cameras its around 16-17 MB/s, not even close to the 133 MB/s limit for PCI.
Is the card inserted all the way in? also, might want to try cleaning the PCI slot and the PCI pins of the card.
