I found these client IP addresses in my apache error log and non of these are addresses
that I have used. Is a strong password enough or do I need a software to protect my
system? thanks.
[Fri Dec 11 01:06:18 2009] [error] [client 71.96.21.105] File does not exist: /var/www/MNG
[Fri Dec 11 07:27:55 2009] [error] [client 121.10.141.208] File does not exist: /var/www/scripts
[Fri Dec 11 07:27:56 2009] [error] [client 121.10.141.208] File does not exist: /var/www/scripts
[Fri Dec 11 07:27:57 2009] [error] [client 121.10.141.208] File does not exist: /var/www/phpMyAdmin
[Fri Dec 11 07:27:58 2009] [error] [client 121.10.141.208] File does not exist: /var/www/sql
[Fri Dec 11 07:27:59 2009] [error] [client 121.10.141.208] File does not exist: /var/www/mysql
[Fri Dec 11 10:57:11 2009] [error] [client 71.96.21.105] File does not exist: /var/www/MNG
[Fri Dec 11 23:34:56 2009] [error] [client 61.139.105.163] File does not exist: /var/www/fastenv
[Sat Dec 12 01:58:17 2009] [error] [client 61.160.216.63] script '/var/www/prx2.php' not found or unable to stat
[Sat Dec 12 05:02:09 2009] [error] [client 89.200.172.132] File does not exist: /var/www/user
[Sat Dec 12 07:09:53 2009] [error] [client 67.18.244.106] File does not exist: /var/www/phpMyAdmin
[Sat Dec 12 07:12:13 2009] [error] [client 67.18.244.106] File does not exist: /var/www/phpmyadmin
Does this mean some one is trying to access my system?
Re: Does this mean some one is trying to access my system?
Yes...a bot is trying to look for insecure systems.
You should install fail2ban: http://www.fail2ban.org/wiki/index.php/Apache
fail2ban won't directly, but any _public_ computer on the internet needs to have fail2ban anyway. Some distros install stupid things by default that are prone to brute force attacks.whatboy wrote:I don't think fail2ban would block that... that is some one typing random links on the browser to your site... fail2ban can only block those who fail to connect...
