ffmpeg streaming and WMP in XP
panadol
Post by panadol »
Hi
From 2day i try to make working streaming in WMP in windows xp. In win98 and wmp7 and wmp9 everything works great. In win xp i try to use WMP10 and WMP9. Unfortunately there is problem with buffering. When buffor com to 90-100% then it start buffering anew.
I try install Media player clasic : http://sourceforge.net/project/showfile ... e_id=84358 and streaming on it with xp work great but i don't found way to use it with window in IE.
And my quastion is : Is there any way to make working WMP9,10 on XP or is this posible to use MPC or mplayer for windows(its work fine too) with ZM page in IE in WINXP ?
I use ZoneMinder LiveCD v1.19.5 i also try 1.19.1ver
Regards
Adam
panadol
Post by panadol »
Hallo
I try to streaming events(not real monitor) and that works on wmp10and9 in xp :o
So i don't know why monitor streaming don't work. Mayby i don't have not enough RAM ?? (256MB) celeron-D 2.4ghz and i capture one monitor 384/288 with bt878 card
