Hi!
I'm Jero and this is my first post in this forum, I have a problem with a camera Axis 210, I can´t view live streaminig in monitor view, only a black screen, this is my system:
* PC:
Debian GNU/Linux Lenny - Dual Core and 4GB RAM
ZoneMinder v1.24.2 installed from sources
*Cameras:
AXIS 206 v4.40 (this works fine)
zmu -m 2 -q -v
Monitor 2(Monitor-2)
Type : Remote
Protocol : http
Host : root:xxxx@xxx.xxx.xxx.xxx
Port : 80
Path : /axis-cgi/jpg/image.cgi?resolution=640x480
Width : 640
Height : 480
Colours : 3
Event Prefix : Event-
Label Format : %N - %y/%m/%d %H:%M:%S
Label Coord : 0,0
Image Buffer Count : 40
Warmup Count : 25
Pre Event Count : 10
Post Event Count : 10
Stream Replay Buffer : 1000
Alarm Frame Count : 1
Section Length : 600
Maximum FPS : 0.00
Alarm Maximum FPS : 0.00
Reference Blend %ge : 7
Track Motion : 0
Function: 2 - Monitor Only
Zones : 1
Label : All
Type: 1 - Active
Shape : 4 points
0: 0,0
1: 639,0
2: 639,479
3: 0,479
Alarm RGB : ff0000
Check Method: 3 - Blobs
Min Pixel Threshold : 25
Max Pixel Threshold : 0
Min Alarm Pixels : 9216
Max Alarm Pixels : 230400
Filter Box : 3,3
Min Filter Pixels : 9216
Max Filter Pixels : 230400
Min Blob Pixels : 6144
Max Blob Pixels : 0
Min Blobs : 1
Max Blobs : 0
AXIS 210 v4.40.1 (this is the problem)
zmu -m 1 -q -v
Monitor 1(Axis210)
Type : Remote
Protocol : http
Host : xxx.xxx.xxx.xxx
Port : 80
Path : /axis-cgi/jpg/video.cgi?resolution=640x480
Width : 640
Height : 480
Colours : 3
Label Coord : 0,0
Warmup Count : 25
Maximum FPS : 0.00
Track Motion : 0
Zones : 1
Label : All
Type: 1 - Active
Shape : 4 points
0: 0,0
1: 639,0
2: 639,479
3: 0,479
Alarm RGB : ff0000
Filter Box : 3,3
Max Blob Pixels : 0
Min Blobs : 1
Max Blobs : 0
*Shared Memory:
kernel.shmmax = 667772160
kernel.shmall = 667772160
tail -n 10 zmwatch.log
16/12/09 14:56:05.179270 zmwatch[2171].ERR [Can't get shared memory id '7a6d0001', 1: No existe el fichero o el directorio]
16/12/09 14:56:15.180205 zmwatch[2171].ERR [Can't get shared memory id '7a6d0001', 1: No existe el fichero o el directorio]
16/12/09 14:56:25.180963 zmwatch[2171].ERR [Can't get shared memory id '7a6d0001', 1: No existe el fichero o el directorio]
16/12/09 14:56:35.181727 zmwatch[2171].ERR [Can't get shared memory id '7a6d0001', 1: No existe el fichero o el directorio]
16/12/09 14:56:45.182484 zmwatch[2171].ERR [Can't get shared memory id '7a6d0001', 1: No existe el fichero o el directorio]
16/12/09 14:56:55.183224 zmwatch[2171].ERR [Can't get shared memory id '7a6d0001',
ipcs -m
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x7a6d0002 262144 www-data 700 36865192 1
I don´t understad why in the logs have shared memory error and I think that is not the problem, but the AXIS 210 not show any image only black screen and if I put de url of Axis Camera in the browser works fine, maybe I need downgrade the camera firmware??
Thanks very much.
Axis 210 problem
The shared memory error will show up any time a configured monitor is unable to capture an image. When zmc fails to get an image and place it in shared memory, zma will complain that it cant find something that it expects. When everything is working, then you should not see shared memory errors.
Thank you for great information though, very detailed. My first suggestion on your first post would have been to enable debug and set around 4 and limit it to zmc_
