I have install from:
http://www.zoneminder.com/forums/viewto ... ght=ubuntu
and zm service on ubuntu 9.10 start on boot but not working until i restart manual the service
in 91.0 i dont have sysconfig and i think fro m here is the problem becasuse in earjier version starts well when activating zm in sysconfig
any ideea pls?
thanks
I'm guessing you missed one of these steps in the instructions.CREATE ZONEMINDER STARTUP SCRIPT
**If you don't know how to use vi then use nano instead for next stop**
vi /etc/init.d/zm
(PASTE THE FOLLOWING)
#!/bin/sh
# description: Control ZoneMinder as a Service
# chkconfig: 2345 99 99
# Source function library.
#. /etc/rc.d/init.d/functions
prog=ZoneMinder
ZM_PATH_BIN="/usr/local/bin"
command="$ZM_PATH_BIN/zmpkg.pl"
start() {
echo -n "Starting $prog: "
$command start
RETVAL=$?
[ $RETVAL = 0 ] && echo success
[ $RETVAL != 0 ] && echo failure
return $RETVAL
stop() {
echo -n "Stopping $prog: "
$command stop
RETVAL=$?
status() {
result=`$command status`
if [ "$result" = "running" ]; then
echo "ZoneMinder is running"
RETVAL=0
else
echo "ZoneMinder is stopped"
RETVAL=1
fi
case "$1" in
'start')
start
'stop')
stop
'restart')
stop
start
'status')
status
echo "Usage: $0 { start | stop | restart | status }"
RETVAL=1
esac
exit $RETVAL
(SAVE AND EXIT)
MAKE ZM STARTUP SCRIPT EXECUTABLE
chmod 755 /etc/init.d/zm
UPDATE /etc/rc.local TO START ZONEMINDER UPON REBOOT
vi /etc/rc.local
ADD THESE LINES:
#Start Zoneminder
/etc/init.d/zm start
Yes! I've missed this step. Now working perfect.UPDATE /etc/rc.local TO START ZONEMINDER UPON REBOOT
vi /etc/rc.local
ADD THESE LINES:
#Start Zoneminder
Thanks.
OSVER: Ubuntu Server 9.10 Karmic
ZMVER: ZoneMinder 1.24.2
DEVICE: Conexant CX23881 (4 Channel) with 2 CCD cams.
VIDEO: GeForce 9400GT 1GB (non-shared)
RAM: 1GB DDR2
CPU: Intel Pentium Dual 2.00GHz
RAM: 1GB DDR2
