- 8 input, 8 chip (bt878) card from camsecure.co.uk.
Asrock K7S41GX motherboard (SiS chipset)
AMD Athlon XP 2200+
1GB RAM
Ubuntu 9.10 Server
options i2c-algo-bit bit_test=1
options bttv gbuffers=32 card=102,102,102,102,102,102,102,102 tuner=0 radio=0 coring=1 full_luma_range=1 chroma_agc=1 pll=1 combfilter=1 autoload=0 triton1=0
When I delete my bttv.conf file and reboot, the system starts under load (~2.50 @ 100% CPU) for about 5 minutes while modprobe is trying to detect my card, htop reports the following process is loading the system:
/sbin/modprobe -b pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00
Next up I tried removing the first line from my original bttv.conf file, so it read as follows:
#options i2c-algo-bit bit_test=1
options bttv gbuffers=32 card=102,102,102,102,102,102,102,102 tuner=0 radio=0 pll=1
So, it would appear that the card type is a 102 (although, it also works if I tell it it's a 77 too) - But how can I get my machine to not have modprobe load the system for 5 minutes trying to figure out what I'm already telling it?
Any guidance is much appreciated.
