I have a problem with my Axis 215 ptz new cam.
the image does not appear and the system don't record anything.
the other axis (a 207w) work's well at 640*480.
I have already tried to increase memory to 428212224 Byte (as the faq says:
kernel.shmall = 428212224
kernel.shmmax = 428212224
the address in host i'have tried are :
/axis-cgi/mjpg/video.cgi?resolution=4CIF
/axis-cgi/mjpg/video.cgi?resolution=705x576
(is not an autentication problem because i use the same autentication parameters than the 207w)
Anyone can help me?
where i'm wrong?
thank you a lot.
i use 1.22.3 on ubuntu latest
*****update****
here the copy of /tmp/zmwatch.log
12/13/07 22:19:40.101882 zmwatch[6256].INF ['zmc -m 3' starting at07/12/13 22:19:40, pid = 6404]
12/13/07 22:19:50.119515 zmwatch[6256].ERR [Can't get shared memory id '7a6d2003', 3: No such file or directory]
12/13/07 22:19:50.119700 zmwatch[6256].INF [Restarting capture daemon for cam, shared memory not valid]
12/13/07 22:19:50.210708 zmwatch[6256].INF ['zmc -m 3' starting at 07/12/13 22:19:50, pid = 6413]
thanks
Stefano
Axis 215ptz problem: zmwatch.log:shared memory not valid
