Sorry guys, been awhile. I did find time to redo the Zoneminder DVD and removed all activation requirements. It is now completly free to install and use for the rest of your life. I would like to send a big thanks to Chuck @
http://www.wifigator.com for hosting the DVD and md5. There is so much to this DVD in terms of security applications and fine tuning security. Upon each install ssh keys are regenerated and there is a webgui with a password changer to lock down all web based applications.
http://update.ilovemywimax.com/zonemind ... 1.24.x.iso
http://update.ilovemywimax.com/zonemind ... .x.iso.md5
Everything has been tested to include ffmpeg, email alerts, overall stability, and multiple usb and remote cameras. We believe we have found a cheap solution in using wireless repeaters for not only Wi-Fi, but for CCTV solutions. The DVD can be installed to most hardware. We highly recommend installing by selecting the direct install option at the initial greeting screen. The screen might go black after selecting install, be patient and the install will proceed by asking a couple short questions.
*new desktop with nxclient remote desktop
*extra web cam drivers installed, DVD only
*support for remote control of mjpg_streamer devices
*complete set of tools to manage your server
*phpmyadmin
*munin
*phpsysinfo
*webmin
*Wine for familar windows programs, DVD only
*8.04 LTS for long term support
added more to 1.24.x
Zoneminder SVN 2859 installed with mmap memory on
Mjpg_Streamer SVN with all plugins and outputs
StreamMinder, complete GUI for controlling Mjpg_streamer
The following programs that work with Zoneminder
ZMviewer aka QT Viewer (setup and working)
jZMConsole server
