Wireless internet conflict with 2.4ghz wireless cameras
Papa Oso
Post by Papa Oso »
I'm using 4 2.4ghz wireless cameras. The problem is when the cameras are working the wireless Internet not. My wireless router is a linksyst wrt54g v2 with tomato firmware. Any suggestion?
kingofkya
Post by kingofkya »
switch to a A frequency router 5.8ghz new cameras , or get ipcams
another thing that MIGHT work is to move fequency of the b/g router to 1 or 6
allanE
Post by allanE »
You might want to consider a second router to handle the cameras. This would unburden the main ( internet ) router. Just set cameras and second router to any freq not used by the main router and it will end the conflict. Cameras tend to be bandwidth hogs
Allan
rynmackz
Post by rynmackz »
I don't know what is the real problem. But I think something wrong with your wireless device so you can't connect. Try to check your router and maybe you need to reset it just like my friend did.
