Hi.
Two days ago I setted up my test environment using Zoneminder 1.24.2 and two Axis M1011 network cameras.
In the stream view window the stream is showed with 1 minute delay compared to the live view of the network camera which is perfectly in real time.
I also tried to setup no maximum FPS and alarm maximum FPS in the monitor setup in Zoneminder and to limit the maximum frame rate at 15fps in the network camera configuration interface, but I didn't solve this problem.
What's the problem? How I can improve this?
Thank you very much!
Bye.
Delay in stream view
make sure you test on different systems
Was having a tough time building and testing my ZM system, including seeing a lot of delay in viewing.
For me, part of the problem was viewing on my Atom based WinXP system my POS stuff is installed on. Lots of lag and eventually stopped displaying. (firefox too)
Switching to Ubuntu/Firefox/Faster system is giving me more consistent view results, even though CPU not maxed out in XP system.
hardware
I agree with Ziggy. In all cases i found that the delay in stream was due to hardware used for pc where zoneminder is installed on. Even though system monitoring werent showing that the CPU/RAM were being utilized to its fullest... the problem/reason lies within motherboard chipset
Hope this makes sense
system
Hi decibel83, can you post the exact model number of your mobo? You mentioned you changed fps rate on network cams themselves...my question to you : is the lagging/delay the same for the network cams as for your rca cam?
Delay
I have the same cameras and here is what I found.
Delays with RTSP, HTTP, anything when the fps is above 6fps or zoneminder controls the fps. Try this and let us know how it goes.
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: user:password@ip address
Remote Host Port: 80
Remote Host Path: /axis-cgi/mjpg/video.cgi?resolution=320x240&compression=20
Remote Image Colors: 24bit color
Capture Width: 320
Capture Height: 240
Maximum FPS: blank
Alarm Max FPS: blank
On the axis camera under video, limit the video stream to 5 fps.
Save and restart zoneminder. This cleared up the delay in video for me.
Capture Width: 320
Capture Height: 240
Maximum FPS: blank
Re: Delay in stream view
I had a similar problem and found that I had to set the fps in zoneminder higher than the fps on the camera itself. i.e. my camera is set to put out 10 fps, and I had to bump ZM up to 20 fps max to get rid of the delay.
