Problem viewing Mpeg stream
amit
Post by amit »
I am able to see stream with jpeg option set..
if I change the option to mpeg I see a gyared out portion...I have the plugin for Mpeg video...
but still nothing appears...
I have cambozola installed
cambolzola.jar is copied to cgi-bin directory but still nothing happens...
I am able to generate videos with ffmpeg option in tools set...
Please help in viewing direct mpeg streamm.
I can view the same from IE... on other windows machine...
________
marijuana joint
zoneminder
Site Admin
Post by zoneminder »
Can you give a little more detail such as what browser you are using, what you clicked to get to what you could or couldn't see and any screenshots if you have them.
Phil,
kim_asplund
Post by kim_asplund »
make sure you have Cambozola writen correctly... filename=name in config... I was almost going mad over a silly problem like that once ;)
amit
Post by amit »
I am using Mozilla on Fedora core machine....
In Video Tab if i set stream method to mpeg instead of jpeg...
and remaining option to be asf..
then i see a frame indicating that i don't have plugin for video/x-ms-asf....
I have the plugin for flash player installed...but don't know what's the problem...
If I set the other options to mpeg ('live' video stream and 'replay' stream ) i see a grayed frame which remains as it is....
I have also installed camozola but to no avail..
Please see if you can help....
________
Ford Model B (1904) picture
