Hello.
Both working with the following parameters:
Linksys WVC54GCA:
Remote Host Name: your.username:your.password@your.ip.address
Remote Host Port: your.port (e.g. 80)
Remote Host Path: /img/mjpeg.cgi
Capture Width: your.width (e.g. 640)
Capture Height: your.height (e.g. 480)
Trendnet TV-IP110W:
The same except for this field:
Remote Host Path: /cgi/mjpg/mjpg.cgi
Cheers,
Linksys WVC54GCA & Trendnet TV-IP110W.
I only said it worked for me with the aforesaid models. Dunno about the "mirco" (micro?) piece you mentioned...Still, as far as Trendnet goes I read here somewhere about different Trendnet models that worked with the "/cgi/mjpg/mjpg.cgi" path.GI Jack wrote:tried this can't seem to get it to work....
I have a trendnet mirco 110
Cheers,
I have the trendnet tv-ip110w i can't get it to work. I know the following two links are vaild for the camera. I just get a blank image place holder.
/cgi/mjpg/mjpg.cgi
/cgi/jpg/image.cgi
If anyone would like to try it i have it up at
http://admin:admin@66.157.34.232:8888
I'm using v1.24.2
/cgi/mjpg/mjpg.cgi
/cgi/jpg/image.cgi
I'm using v1.24.2
Both settings either snapshot or mjpeg work fine for me here with the following settings:
Remote Host Name: admin:admin@66.157.34.232
Remote Host Port: 8888
Remote Host Path: /cgi/jpg/image.cgi
