Won't stream video
The AddHandler directive means that your test script would work even if the cgi-bin wasn't set up properly. Rename it to something without a .cgi extension and try again. Also could you post the contents of the test script?stimburg wrote:Just to test to see if a cgi could be parsed by my webserver I created a test.cgi and placed it in the same directory as the zms file. It's a simple cgi script set up to print hello world and works fine in the browser. The web server parsed it with no problems.
I noticed this line
AddHandler cgi-script .cgi .pl
#!/usr/bin/perl
print "Content-type: text/plain\n\Hello World!\n";
Okay, make sure the test script has the execute bit set and try again.
If it still just shows the code then edit your http.conf file and make sure the following is in it:
This is assuming the cgi-bin is located in /var/www/htdocs/cgi-bin
If its somewhere else then use that location.
ScriptAlias /cgi-bin/ "/var/www/htdocs/cgi-bin/"
<Directory "/var/www/htdocs/cgi-bin/">
AllowOverride None
Options +ExecCGI -Includes
Order allow,deny
Allow from all
</Directory>
Can you post the apache config file on pastebin please
as well as a tail of the following log, apache error_log,
and what path is configured in zm.conf for ZM_PATH_CGI
and iin the ZM Options/paths/ ZM_PATH_ZMS?
Did you make a backup of the config files before you changed/touched any of them and what else might have you changed?
Just to be sure, this is on a Slackware 13 installation?
Apache httpd.confcordel wrote:Can you post the apache config file on pastebin please
http://pastebin.com/mb9a171e
ZM_PATH_CGI=/var/www/htdocs/zm/cgi-bin/
PATH_ZMS zm/cgi-bin/zms
This is Slackware 13 and I don't have a backup copy of httpd.conf. The only thing this system did before installing a 4 port video card was a DNS masquerade and backup file storage. It's pretty much a virgin copy of slackware besides that. Just put it together a few months ago to replace an older dying box I had that I did the same things with.
ScriptAlias /cgi-bin/ "/var/www/htdocs/zm/cgi-bin/"
<Directory "/var/www/htdocs/zm/cgi-bin/">
AllowOverride None
Order allow,deny
Allow from all
</Directory>
PATH_ZMS should be;PATH_ZMS zm/cgi-bin/zms
PATH_ZMS cgi-bin/zms
As it is define above in your script alias as from the web root cgi-bin/
In some fashion, the cgi-bin directory has become available to the web root though and I have not noticed where that is happening but is a security concern. You should not be able to download the script. But one thing at a time.
Also, above your script alias:
You would not typically set ExecCGI in your web root and is another security concern<Directory "/srv/httpd/htdocs">
Options Indexes FollowSymLinks SymLinksifOwnerMatch ExecCGI
that you should be aware of. Though please work one change at a time incase the behavior changes inappropriately, you know what change it was that has done it.
