Is there a public live demo of ZoneMinder 1.24? I am not tech savvy so would like to see a live demo before hiring someone to install/setup one on my server.
thanks,
John
ZoneMinder 1.24 Demo?
Take a look at the link in the first post of this topic :
http://www.zoneminder.com/forums/viewtopic.php?t=12915
It points to a live demo of Zoneminder.
Hope it helps,
PacoLM
Hope it helps,
PacoLM
Thanks. I already went to the site and downloaded the
# putty-0.58-installer.exe
# winscp403setup.exe
but still not able to view the server control panel which asks for other info like host name, Port number....I really just want to see demo of live camera script (zoneminder) and not the server control panel.
thanks,
John
thanks,
John
If you only want to see a camera working, you don't need putty or anything else, go to http://67.210.200.98/zm/ , use admin/admin for user pwd, and then click in one of the enabled cameras under the column Name. Right now the system seems stopped, but I logged in yesterday and the monitor was working. If doesn't work, I could give you access as guest to my remote system at home (private message).
Maybe I don't understand what a live camera script is (sorry), and this is not the information you're looking for.
Regards,
Paco
Regards,
Paco
