adub
Posts: 26 Joined: Fri Nov 21, 2008 1:10 am
Post
by adub » Tue Feb 09, 2010 6:12 pm
does anyone have any insight to setup an automatic delete of events and/or images that are stored on the hard drive??
I seen a post for events from the database. Was wondering if anyone had tested this script.
Thanks to all who reply
adub
Post
by adub » Tue Feb 09, 2010 6:13 pm
also when you delete events will it delete the images as well
From what I recall I dont think it does but maybe it does I am unsure the script worked with the mysql database
Paranoid
Posts: 129 Joined: Thu Feb 05, 2009 10:40 pm
Post
by Paranoid » Fri Feb 12, 2010 11:47 am
zmaudit.pl performs this task. It will delete images/events from the hard drive that dont have a corresponding entry in the database and vice-versa.
You can set zmaudit to run periodically via the options menu.
mastertheknife
Posts: 678 Joined: Wed Dec 16, 2009 4:32 pm
Post
by mastertheknife » Fri Feb 12, 2010 1:04 pm
Use filters. You can create your own or use the PurgeWhenFull filter or modify it and save under a new name.
Then you need to enable run in background..
kevin_robson
Posts: 247 Joined: Sun Jan 16, 2005 11:26 am
Post
by kevin_robson » Fri Feb 12, 2010 1:28 pm
Also check whether ZM_OPT_FAST_DELETE is set in options.
If it is then the diskspace will not be reclaimed until you restart zm, which probably isn't what you want.
Paranoid
Post
by Paranoid » Fri Feb 12, 2010 2:34 pm
kevin_robson wrote: Also check whether ZM_OPT_FAST_DELETE is set in options.
zmaudit will reclaim the disk space without restarting zm
