Yesterday, two times power cut happend in my region. So my ZM server had power loss two times too. When I power on my zm server today again, it was not continue recording in Mocord function and source path was orange. I tried reboot server, restart zm service from tty, restart from web interface and changing back function again and again, but nothing changed.
I searched in forum and the FAQS and i saw it might be about database problem. Then i tried this instruction to fix database. Bu didn't help. The problem is still continue.
There are the first 94 rows from zm_debug.log of the running device (/dev/video3)
(I didnt paste all of log, because each log files are about 7KB)
01/07/10 16:04:53.780219 zmc_dvideo3[1762].INF-zm_debug.c/296 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.01762]
01/07/10 16:04:53.780959 zmc_dvideo3[1762].DB1-zm_monitor.cpp/1723 [Got 1 monitors]
01/07/10 16:04:53.781050 zmc_dvideo3[1762].DB2-zm_local_camera.cpp/286 [V4L2 support enabled, using V4L1 api]
01/07/10 16:04:53.781583 zmc_dvideo3[1762].DB1-zm_monitor.cpp/338 [monitor purpose=1]
01/07/10 16:04:53.781612 zmc_dvideo3[1762].DB1-zm_monitor.cpp/345 [mem.size=9217192]
01/07/10 16:04:53.781693 zmc_dvideo3[1762].DB1-zm_monitor.cpp/369 [Unable to map file /dev/shm/zm.mmap.3 (9217192 bytes) to locked memory, trying unlocked]
01/07/10 16:04:53.795203 zmc_dvideo3[1762].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
01/07/10 16:04:53.796855 zmc_dvideo3[1762].DB1-zm_monitor.cpp/458 [Monitor Kapi has function 5]
01/07/10 16:04:53.796882 zmc_dvideo3[1762].DB1-zm_monitor.cpp/459 [Monitor Kapi LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
01/07/10 16:04:53.796893 zmc_dvideo3[1762].DB1-zm_monitor.cpp/460 [Monitor Kapi IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
01/07/10 16:04:53.816800 zmc_dvideo3[1762].DB1-zm_zone.cpp/889 [Got 1 zones for monitor Kapi]
01/07/10 16:04:53.816839 zmc_dvideo3[1762].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 319,0 319,239 0,239]
01/07/10 16:04:53.816852 zmc_dvideo3[1762].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 319,0 319,239 0,239']
01/07/10 16:04:53.816864 zmc_dvideo3[1762].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
01/07/10 16:04:53.816875 zmc_dvideo3[1762].DB3-zm_zone.cpp/796 [Got coordinate 319,0 from polygon string]
01/07/10 16:04:53.816886 zmc_dvideo3[1762].DB3-zm_zone.cpp/796 [Got coordinate 319,239 from polygon string]
01/07/10 16:04:53.816896 zmc_dvideo3[1762].DB3-zm_zone.cpp/796 [Got coordinate 0,239 from polygon string]
01/07/10 16:04:53.816911 zmc_dvideo3[1762].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
01/07/10 16:04:53.816923 zmc_dvideo3[1762].DB1-zm_zone.cpp/50 [Initialised zone 3/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2304, MxAP:57600, FB:3x3, MnFP:2304, MxFP:57600, MnBS:1536, MxBS:0, MnB:1, MxB:0, OF: 0]
01/07/10 16:04:53.818525 zmc_dvideo3[1762].DB1-zm_monitor.cpp/1825 [Loaded monitor 3(Kapi), 1 zones]
01/07/10 16:04:53.818549 zmc_dvideo3[1762].INF-zmc.cpp/188 [Starting Capture]
01/07/10 16:04:53.818643 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/349 [Opening video device /dev/video3]
01/07/10 16:04:53.818679 zmc_dvideo3[1762].DB2-zm_local_camera.cpp/355 [V4L2 support enabled, using V4L1 api]
01/07/10 16:04:53.818691 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/502 [Configuring picture attributes]
01/07/10 16:04:53.818721 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/509 [Old P:4]
01/07/10 16:04:53.818732 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/510 [Old D:24]
01/07/10 16:04:53.818743 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/511 [Old B:32639]
01/07/10 16:04:53.818753 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/512 [Old h:32639]
01/07/10 16:04:53.818763 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/513 [Old Cl:32639]
01/07/10 16:04:53.818773 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/514 [Old Cn:16191]
01/07/10 16:04:53.818793 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/551 [Configuring window attributes]
01/07/10 16:04:53.818806 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/560 [Old X:0]
01/07/10 16:04:53.818818 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/561 [Old Y:0]
01/07/10 16:04:53.818828 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/562 [Old W:320]
01/07/10 16:04:53.818839 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/563 [Old H:240]
01/07/10 16:04:53.818853 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/578 [Setting up request buffers]
01/07/10 16:04:53.818873 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/584 [vmb.frames = 8]
01/07/10 16:04:53.818884 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/585 [vmb.size = 1867776]
01/07/10 16:04:53.818895 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/587 [Setting up 8 frame buffers]
01/07/10 16:04:53.818968 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/612 [Configuring video source]
01/07/10 16:04:53.818986 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/620 [Old C:0]
01/07/10 16:04:53.818997 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/621 [Old F:1]
01/07/10 16:04:53.819008 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/622 [Old Fl:1]
01/07/10 16:04:53.819018 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/623 [Old T:1]
01/07/10 16:04:53.947022 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/638 [New X:0]
01/07/10 16:04:53.947053 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/639 [New Y:0]
01/07/10 16:04:53.947064 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/640 [New W:320]
01/07/10 16:04:53.947075 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/641 [New H:240]
01/07/10 16:04:53.947096 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/646 [New P:4]
01/07/10 16:04:53.947107 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/647 [New D:24]
01/07/10 16:04:53.947117 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/648 [New B:32639]
01/07/10 16:04:53.947127 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/649 [New h:32639]
01/07/10 16:04:53.947137 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/650 [New Cl:32639]
01/07/10 16:04:53.947147 zmc_dvideo3[1762].DB4-zm_local_camera.cpp/651 [New Cn:16191]
01/07/10 16:04:53.947157 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/654 [Setting up static colour tables]
01/07/10 16:04:53.947177 zmc_dvideo3[1762].DB2-zm_local_camera.cpp/1439 [Priming capture]
01/07/10 16:04:53.947188 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1471 [Queueing frame 0]
01/07/10 16:04:53.947382 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1471 [Queueing frame 1]
01/07/10 16:04:53.947557 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1471 [Queueing frame 2]
01/07/10 16:04:53.947757 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1471 [Queueing frame 3]
01/07/10 16:04:53.947956 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1471 [Queueing frame 4]
01/07/10 16:04:53.948166 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1471 [Queueing frame 5]
01/07/10 16:04:53.948376 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1471 [Queueing frame 6]
01/07/10 16:04:53.948591 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1471 [Queueing frame 7]
01/07/10 16:04:53.948845 zmc_dvideo3[1762].DB2-zm_local_camera.cpp/1485 [Pre-capturing]
01/07/10 16:04:53.948868 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1491 [Capturing]
01/07/10 16:04:53.948882 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1546 [Capturing 1 frames]
01/07/10 16:04:53.948892 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1549 [Syncing frame 0]
01/07/10 16:04:53.982631 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1567 [Captured 0 for channel 0]
01/07/10 16:04:53.982664 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1572 [Doing format conversion]
01/07/10 16:04:53.983086 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1878 [Assigning image]
01/07/10 16:04:53.983378 zmc_dvideo3[1762].DB2-zm_local_camera.cpp/1886 [Post-capturing]
01/07/10 16:04:53.983395 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1944 [Requeueing frame 0]
01/07/10 16:04:53.983425 zmc_dvideo3[1762].DB2-zm_local_camera.cpp/1485 [Pre-capturing]
01/07/10 16:04:53.983436 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1491 [Capturing]
01/07/10 16:04:53.983446 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1546 [Capturing 1 frames]
01/07/10 16:04:53.983457 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1549 [Syncing frame 1]
01/07/10 16:04:54.019132 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1567 [Captured 1 for channel 0]
01/07/10 16:04:54.019168 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1572 [Doing format conversion]
01/07/10 16:04:54.019421 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1878 [Assigning image]
01/07/10 16:04:54.019823 zmc_dvideo3[1762].DB2-zm_local_camera.cpp/1886 [Post-capturing]
01/07/10 16:04:54.019845 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1944 [Requeueing frame 1]
01/07/10 16:04:54.019884 zmc_dvideo3[1762].DB2-zm_local_camera.cpp/1485 [Pre-capturing]
01/07/10 16:04:54.019900 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1491 [Capturing]
01/07/10 16:04:54.019912 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1546 [Capturing 1 frames]
01/07/10 16:04:54.019996 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1549 [Syncing frame 2]
01/07/10 16:04:54.071710 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1567 [Captured 2 for channel 0]
01/07/10 16:04:54.071744 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1572 [Doing format conversion]
01/07/10 16:04:54.071971 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1878 [Assigning image]
01/07/10 16:04:54.072326 zmc_dvideo3[1762].DB2-zm_local_camera.cpp/1886 [Post-capturing]
01/07/10 16:04:54.072342 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1944 [Requeueing frame 2]
01/07/10 16:04:54.072376 zmc_dvideo3[1762].DB2-zm_local_camera.cpp/1485 [Pre-capturing]
01/07/10 16:04:54.072391 zmc_dvideo3[1762].DB3-zm_local_camera.cpp/1491 [Capturing]
I'm recording images to a additional drive (/dev/sdb1) which is mounted at init
/dev/sda5 on / type ext3 (rw,relatime,errors=remount-ro)
proc on /proc type proc (rw)
none on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
udev on /dev type tmpfs (rw,mode=0755)
none on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
none on /dev/shm type tmpfs (rw,nosuid,nodev)
none on /var/run type tmpfs (rw,nosuid,mode=0755)
none on /var/lock type tmpfs (rw,noexec,nosuid,nodev)
none on /lib/init/rw type tmpfs (rw,nosuid,mode=0755)
/dev/sdb1 on /var/www/events type ext3 (rw,noatime)
