Zoneminder 1.24.2 for FreeBSD 8.0-RELEASE
white_raven
Post by white_raven »
Fixed port for FreeBSD 8.0-RELEASE
Fixes:
  • deps
    now build with default apache and mysql version
    default mysql engine changed to innodb
    on i386 and amd64 link with static libjpeg-turbo library
    from http://www.virtualgl.org/DeveloperInfo/Libjpeg
    is 4X times fastest then standart system lib
    on my Celeron 420 1.60GHz CPU load drop down
    from 95% to 12%!
    patches for stability on bugged mjpeg streaming
    cameras like my TRENDNet TV-IP201 and TV-IP110
    now may be used on TV-IP201 /goform/video2 as
    remote path instead of /goform/capture
    and on TV-IP110 /cgi/mjpg/mjpeg.cgi instead of
    /cgi/jpg/image.cgi
    fix system load show in http console
    and other small fixes
Port can be downloaded there: http://white-raven.pisem.net/zoneminder ... 8.0.tar.gz
Package for i386: http://white-raven.pisem.net/zoneminder ... 24.2_2.tbz
estranged1977
Post by estranged1977 »
Hi Im using freeBSD 8 64 bits, I try installing using make install but after some minutes working it says "checking if we have SIMD optimisations for cpu type... no ("amd64")" and then stops with.
"configure: error: CPU is not supported"
Any idea??
smf
ERROR
Post by smf »
pci card Kodicom 4400
FreeBSD8 i386
Log file:
Feb 17 07:56:13 smr zmc_dtuner0[15473]: FAT [Failed to get picture attributes  VIDIOCGPICT: Inappropriate ioctl for device]
Feb 17 07:56:13 smr zmdc[1106]: ERR ['zmc -d /dev/tuner0' exited abnormally, exit status 6]
Feb 17 07:58:53 smr zmc_dtuner0[15507]: FAT [Failed to get picture attributes VIDIOCGPICT: Inappropriate ioctl for device]
Error appears on line 507 zm_local_camera.cpp
Please help to correct it.
white_raven
estranged1977 wrote:Hi Im using freeBSD 8 64 bits, I try installing using make install but after some minutes working it says "checking if we have SIMD optimisations for cpu type... no ("amd64")" and then stops with.
Any idea??
Please try this: http://white-raven.pisem.net/zoneminder ... 8.0.tar.gz
And tell me about result.
estranged1977
Hi, thanks for answer, well the first error is now off but now appears this:
build jpeg-turbo library
make all-recursive
Making all in simd
gcc -E -I.. -I../simd ./jsimdcfg.inc.h | /usr/bin/grep -E "^[\;%]|^\ %" | sed 's%_cpp_protection_%%' | sed 's@% define@%define@g' > jsimdcfg.inc
make all-am
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I.. -I.. -O3 -MT jsimd_x86_64.lo -MD -MP -MF .deps/jsimd_x86_64.Tpo -c -o jsimd_x86_64.lo jsimd_x86_64.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I.. -I.. -O3 -MT jsimd_x86_64.lo -MD -MP -MF .deps/jsimd_x86_64.Tpo -c jsimd_x86_64.c -o jsimd_x86_64.o
mv -f .deps/jsimd_x86_64.Tpo .deps/jsimd_x86_64.Plo
/bin/sh ../libtool --mode=compile --tag NASM ./nasm_lt.sh nasm -felf -DELF -I. jfsseflt-64.asm -o jfsseflt-64.lo
libtool: compile: ignoring unknown tag NASM
libtool: compile: ./nasm_lt.sh nasm -felf -DELF -I. jfsseflt-64.asm -o jfsseflt-64.o
nasm -felf -DELF -I./ jfsseflt-64.asm -o jfsseflt-64.o
jfsseflt-64.asm:54: error: elf output format does not support 64-bit code
jfsseflt-64.asm:75: error: impossible combination of address sizes
jfsseflt-64.asm:77: error: impossible combination of address sizes
jfsseflt-64.asm:86: error: impossible combination of address sizes
jfsseflt-64.asm:86: error: invalid effective address
jfsseflt-64.asm:87: error: impossible combination of address sizes
jfsseflt-64.asm:87: error: invalid effective address
jfsseflt-64.asm:88: error: impossible combination of address sizes
jfsseflt-64.asm:88: error: invalid effective address
jfsseflt-64.asm:89: error: impossible combination of address sizes
jfsseflt-64.asm:89: error: invalid effective address
jfsseflt-64.asm:101: error: impossible combination of address sizes
jfsseflt-64.asm:101: error: invalid effective address
jfsseflt-64.asm:102: error: impossible combination of address sizes
jfsseflt-64.asm:102: error: invalid effective address
jfsseflt-64.asm:103: error: impossible combination of address sizes
jfsseflt-64.asm:103: error: invalid effective address
jfsseflt-64.asm:104: error: impossible combination of address sizes
jfsseflt-64.asm:104: error: invalid effective address
jfsseflt-64.asm:109: error: impossible combination of address sizes
jfsseflt-64.asm:109: error: invalid effective address
jfsseflt-64.asm:110: error: impossible combination of address sizes
jfsseflt-64.asm:110: error: invalid effective address
jfsseflt-64.asm:133: error: impossible combination of address sizes
jfsseflt-64.asm:133: error: invalid effective address
jfsseflt-64.asm:134: error: impossible combination of address sizes
jfsseflt-64.asm:134: error: invalid effective address
jfsseflt-64.asm:135: error: impossible combination of address sizes
jfsseflt-64.asm:135: error: invalid effective address
jfsseflt-64.asm:136: error: impossible combination of address sizes
jfsseflt-64.asm:136: error: invalid effective address
jfsseflt-64.asm:171: error: impossible combination of address sizes
jfsseflt-64.asm:171: error: invalid effective address
jfsseflt-64.asm:172: error: impossible combination of address sizes
jfsseflt-64.asm:172: error: invalid effective address
jfsseflt-64.asm:173: error: impossible combination of address sizes
jfsseflt-64.asm:173: error: invalid effective address
jfsseflt-64.asm:174: error: impossible combination of address sizes
jfsseflt-64.asm:174: error: invalid effective address
jfsseflt-64.asm:178: error: impossible combination of address sizes
jfsseflt-64.asm:178: error: invalid effective address
jfsseflt-64.asm:179: error: impossible combination of address sizes
jfsseflt-64.asm:179: error: invalid effective address
jfsseflt-64.asm:206: error: impossible combination of address sizes
jfsseflt-64.asm:206: error: invalid effective address
jfsseflt-64.asm:207: error: impossible combination of address sizes
jfsseflt-64.asm:207: error: invalid effective address
jfsseflt-64.asm:208: error: impossible combination of address sizes
jfsseflt-64.asm:208: error: invalid effective address
jfsseflt-64.asm:209: error: impossible combination of address sizes
jfsseflt-64.asm:209: error: invalid effective address
jfsseflt-64.asm:221: error: impossible combination of address sizes
jfsseflt-64.asm:221: error: invalid effective address
jfsseflt-64.asm:222: error: impossible combination of address sizes
jfsseflt-64.asm:222: error: invalid effective address
jfsseflt-64.asm:223: error: impossible combination of address sizes
jfsseflt-64.asm:223: error: invalid effective address
jfsseflt-64.asm:224: error: impossible combination of address sizes
jfsseflt-64.asm:224: error: invalid effective address
jfsseflt-64.asm:236: error: impossible combination of address sizes
jfsseflt-64.asm:236: error: invalid effective address
jfsseflt-64.asm:237: error: impossible combination of address sizes
jfsseflt-64.asm:237: error: invalid effective address
jfsseflt-64.asm:238: error: impossible combination of address sizes
jfsseflt-64.asm:238: error: invalid effective address
jfsseflt-64.asm:239: error: impossible combination of address sizes
jfsseflt-64.asm:239: error: invalid effective address
jfsseflt-64.asm:244: error: impossible combination of address sizes
jfsseflt-64.asm:244: error: invalid effective address
jfsseflt-64.asm:245: error: impossible combination of address sizes
jfsseflt-64.asm:245: error: invalid effective address
jfsseflt-64.asm:268: error: impossible combination of address sizes
jfsseflt-64.asm:268: error: invalid effective address
jfsseflt-64.asm:269: error: impossible combination of address sizes
jfsseflt-64.asm:269: error: invalid effective address
jfsseflt-64.asm:270: error: impossible combination of address sizes
jfsseflt-64.asm:270: error: invalid effective address
jfsseflt-64.asm:271: error: impossible combination of address sizes
jfsseflt-64.asm:271: error: invalid effective address
jfsseflt-64.asm:306: error: impossible combination of address sizes
jfsseflt-64.asm:306: error: invalid effective address
jfsseflt-64.asm:307: error: impossible combination of address sizes
jfsseflt-64.asm:307: error: invalid effective address
jfsseflt-64.asm:308: error: impossible combination of address sizes
jfsseflt-64.asm:308: error: invalid effective address
jfsseflt-64.asm:309: error: impossible combination of address sizes
jfsseflt-64.asm:309: error: invalid effective address
jfsseflt-64.asm:313: error: impossible combination of address sizes
jfsseflt-64.asm:313: error: invalid effective address
jfsseflt-64.asm:314: error: impossible combination of address sizes
jfsseflt-64.asm:314: error: invalid effective address
jfsseflt-64.asm:341: error: impossible combination of address sizes
jfsseflt-64.asm:341: error: invalid effective address
jfsseflt-64.asm:342: error: impossible combination of address sizes
jfsseflt-64.asm:342: error: invalid effective address
jfsseflt-64.asm:343: error: impossible combination of address sizes
jfsseflt-64.asm:343: error: invalid effective address
jfsseflt-64.asm:344: error: impossible combination of address sizes
jfsseflt-64.asm:344: error: invalid effective address
*** Error code 1
Stop in /usr/home/boss/zm/zoneminder/work/libjpeg-turbo/simd.
*** Error code 1
*** Error code 1
Stop in /usr/home/boss/zm/zoneminder/work/libjpeg-turbo.
*** Error code 1
*** Error code 1
Stop in /usr/home/boss/zm/zoneminder.
Maybe im doing something wrong?? I just did "make install", is that Ok right??
passat
The same error
Post by passat »
The same error
kelley
The problem is ELF64
Post by kelley »
freebsd* | netbsd* | openbsd*)
    if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
      objfmt='BSD-a.out'
    else
      objfmt='ELF'
    fi
There is no check for 64-bit with Freebsd in libjpeg-turbo. It should be something more like the following, for FreeBSD at least .. not sure about 64bit OpenBSD or NetBSD
      objfmt='BSD-a.out'
    else
      case "$host_cpu" in
        amd64)
          objfmt='ELF64'
          objfmt='ELF'
      esac
    fi
Then you just need to
autoreconf --force
and
libtoolize --force
then it builds just fine.
On a semi-related note, why has this port not been submitted to FreeBSD for inclusion into the ports collection?
bytestore
Post by bytestore »
i install this port on my freebsd 8 :)
its work, but this port have bugs on my server or cameras
1 download acinclude.m4 from 167 svn
http://libjpeg-turbo.svn.sourceforge.ne ... athrev=167
edit this file
      objfmt='BSD-a.out'
    else
      case "$host_cpu" in
        x86_64)
          objfmt='ELF64'
          objfmt='ELF'
      esac
    fi
on
      objfmt='BSD-a.out'
    else
      case "$host_cpu" in
        amd64)
          objfmt='ELF64'
          objfmt='ELF'
      esac
    fi
and place this file into /files
2 edit Makefile
pre-configure:
@${ECHO_CMD} configure jpeg-turbo library
#@cd ${WRKDIR} && ${LOCALBASE}/bin/svn co --non-interactive --trust-server-cert https://libjpeg-turbo.svn.sourceforge.net/svnroot/libjpeg-turbo/trunk
@cd ${WRKDIR}/libjpeg-turbo && ${AUTORECONF} -fiv && ./configure CFLAGS='-O3' CXXFLAGS='-O3' --enable-static=yes --enable-shared=no
on
pre-configure:
@cd ${WRKDIR} && cp ../files/acinclude.m4 libjpeg-turbo
and compile port
3 when port installed i run zm
add 5 DCS-900 camera (/mjpeg.cgi)
add 6 DCS-910 camera (/mjpeg.cgi)
all camera work but i see in logs this
  • Apr 8 18:46:44 video zma_m3[746]: INF [kurskaya27: 14000 - Processing at 6.21 fps]
    Apr 8 18:46:44 video zmc_m2[740]: WAR [Corrupt JPEG data: 3 extraneous bytes before marker 0xd0]
    Apr 8 18:46:44 video zmc_m10[772]: WAR [Corrupt JPEG data: 3 extraneous bytes before marker 0xd0]
    Apr 8 18:46:44 video zmc_m10[772]: WAR [Corrupt JPEG data: 2 extraneous bytes before marker 0xd0]
    Apr 8 18:46:44 video zmc_m8[764]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd0]
    Apr 8 18:46:44 video zmc_m2[740]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd0]
    Apr 8 18:46:44 video zmc_m10[772]: WAR [Corrupt JPEG data: 1 extraneous bytes before marker 0xd0]
    Apr 8 18:46:44 video zmc_m8[764]: WAR [Corrupt JPEG data: 2 extraneous bytes before marker 0xd0]
    Apr 8 18:46:44 video zmc_m2[740]: WAR [Corrupt JPEG data: 2 extraneous bytes before marker 0xd0]
    Apr 8 18:46:45 video zmc_m2[740]: WAR [Corrupt JPEG data: 3 extraneous bytes before marker 0xd0]
    Apr 8 18:46:45 video zmc_m10[772]: WAR [Corrupt JPEG data: 3 extraneous bytes before marker 0xd0]
    Apr 8 18:46:45 video zmwatch[784]: ERR [Shared data size conflict in shared_data for monitor degtyarnaya5_7, expected 316, got 328]
    Apr 8 18:46:45 video zmwatch[784]: ERR [Shared data size conflict in shared_data for monitor Salova56-401, expected 316, got 328]
    Apr 8 18:46:45 video zmwatch[784]: ERR [Shared data size conflict in shared_data for monitor kurskaya27, expected 316, got 328]
    Apr 8 18:46:45 video zmwatch[784]: ERR [Shared data size conflict in shared_data for monitor ilich_K, expected 316, got 328]
and in apache.log
  • [Thu Apr 08 18:15:02 2010] [error] [client 192.168.253.109] socket_sendto( /tmp/zms-885860s.sock ) failed: Connection refused, referer: http://myweb
    /?view=event&eid=101&trms=1&attr1=MonitorId&op1=%3d&val1=11&page=1
    [Thu Apr 08 18:15:02 2010] [error] [client 192.168.253.109] array (\n 0 => \n array (\n 'file' => '/usr/local/www/apache22/data/zm/ajax/stream.php',\n
    'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-885860s.sock ) failed: Connection refused',
    \n ),\n ),\n 1 => \n array (\n 'file' => '/usr/local/www/apache22/data/zm/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '
    /usr/local/www/apache22/data/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://myweb/?view=event&eid=101&trm
achix
Re: ERROR
Post by achix »
smf wrote:pci card Kodicom 4400
FreeBSD8 i386
Log file:
apparently the port is incomplete, since it obviously contains the original linux code to handle local (non-IP) cameras (which imo are so cheap that they definitely provide a very good alternative as opposed to IP cameras, most of them nowadays contain a system like zoneminder in theirself).
One needs to rewrite the local camera code, like i did in the 1.23 port.
Now, if someone makes a complete 1.24 port, that would be great.
What would be even greater, would be, if someone actual submitted it as an official port in the multimedia port subtree.
