When I had ZoneMinder configured for Http 1.1, the program couldn't seem to get an image from the camera and timed out every time. In looking at the debug output, it appears that ZM couldn't figure out when it had received the last batch of data from the web server and would just sit there until the timeout was reached. When I changed ZM to use Http 1.0, then it would detect that it had gotten all the data because the server closed the connection. I'm not sure if there is a problem with the way the cgi script is handling the output, or something else. It's working as long as I use the http 1.0, but here's the pertinent entries from the syslog.
Using HTTP 1.1
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB2 [Request: GET /ipcam/cgi-bin/webveo.cgi?action=getimage HTTP/1.1 User-Agent: ZoneMinder/1.19.5 Host: homeauto Connection: Keep-Alive Authorization: Basic xxxxxxxxxxxxx ]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB1 [monitor purpose=1]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB1 [shm.size=3456108]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB1 [Initialised zone 0/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB1 [Monitor Veo has function 3]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB1 [Monitor Veo LBF = '%%s - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB1 [Monitor Veo IBC = 15, WUC = 4, pEC = 3, PEC = 3, EAF = 2, FRI = 1000, RBP = 10]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB1 [Got 1 zones for monitor Veo]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB1 [Initialised zone 3/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2304, MxAP:57600, FB:3x3, MnFP:2304, MxFP:57600, MnBS:1536, MxBS:0, MnB:1, MxB:0]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB1 [Loaded monitor 3(Veo), 1 zones]
Jan 1 23:50:09 homeauto zmc_m3[3288]: INF [Starting Capture]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB3 [Connected to host, socket = 5]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB3 [Request sent]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB3 [Expecting 4329 bytes]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB3 [Read 4329 bytes]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB4 [Captured header (252 bytes): 'HTTP/1.1 200 OK
Date: Sun, 02 Jan 2005 07:50:09 GMT
Server: Apache/1.3.33 (Debian GNU/Linux) PHP/4.3.10-2 mod_ssl/2.8.22 OpenSSL/0.9.7d
Keep-Alive: timeout=15, max=100
Transfer-Encoding: chunked
Content-Type: image/jpeg']
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB3 [Got status '200' (OK), http version 1.1]
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB3 [Got connection 'Keep-Alive']
Jan 1 23:50:09 homeauto zmc_m3[3288]: DB3 [Got content type 'image/jpeg' ]
Jan 1 23:50:10 homeauto zmc_m3[3288]: DB3 [Expecting 1244 bytes]
Jan 1 23:50:10 homeauto zmc_m3[3288]: DB3 [Read 1244 bytes]
Jan 1 23:50:13 homeauto zmc_m3[3288]: ERR [Select timed out]
Using HTTP 1.0
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB2 [Request: GET /ipcam/cgi-bin/webveo.cgi?action=getimage HTTP/1.0 User-Agent: ZoneMinder/1.19.5 Host: homeauto Connection: Keep-Alive Authorization: Basic xxxxxxxxxxxxx ]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB1 [monitor purpose=1]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB1 [shm.size=3456108]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB1 [Initialised zone 0/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB1 [Monitor Veo has function 3]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB1 [Monitor Veo LBF = '%%s - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB1 [Monitor Veo IBC = 15, WUC = 4, pEC = 3, PEC = 3, EAF = 2, FRI = 1000, RBP = 10]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB1 [Got 1 zones for monitor Veo]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB1 [Initialised zone 3/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2304, MxAP:57600, FB:3x3, MnFP:2304, MxFP:57600, MnBS:1536, MxBS:0, MnB:1, MxB:0]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB1 [Loaded monitor 3(Veo), 1 zones]
Jan 1 23:55:53 homeauto zmc_m3[3354]: INF [Starting Capture]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Connected to host, socket = 5]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Request sent]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Expecting 4256 bytes]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Read 4256 bytes]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB4 [Captured header (186 bytes): 'HTTP/1.1 200 OK
Date: Sun, 02 Jan 2005 07:55:53 GMT
Connection: close
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Got status '200' (OK), http version 1.1]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Got connection 'close']
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Got content type 'image/jpeg' ]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Expecting 1326 bytes]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Read 1326 bytes]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Expecting 0 bytes]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Socket closed]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Got end of image by closure, content-length = 5396]
Jan 1 23:55:53 homeauto zmc_m3[3354]: DB3 [Returning 5396 (5396) bytes of captured content]
