All,
I was looking for a couple of IP cameras for ZM and did not want to get carried away on cost. I got a couple Q Serial IP cams on e-bay. I was having trouble getting them to work so I started poking around the Wiki.
For anyone who gets one.
Remote Host Path = /cgi-bin/getimage.cgi?motion=1
This will get them up an running. Just wanted to share.
Enjoy,
Ron
Q-Serial Cameras on e-bay - Success
That's it
I see that there are more on e-bay. I also just got another camera. This one has a smaller footprint and works well. Same settings and appears to have the same internals.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... K:MEWAX:IT
Regards,
Ron
Regards,
Ron
Re: Q-Serial Cameras on e-bay - Success
Urg that part that sucks is when folks link to a product on ebay and you read it more then 90 days later. maybe if they are still sold someone could post the fellows nickname or link to items they sell or folks that sell similar but not the actual item with out also mentioning the fellows user name so that we have a chance in heck getting ahold of them or check out said product.
The link is dead anyone have any links??
I have two cameras of this type (or really similar), also bought from DX, and I was using the following path to get the image:
I have tested:
Both of them work, so now we have two options. About the commands, anyone has the command list?. I would like to know what means the 'motion=1', for instance.
Kind regards,
PacoLM
Remote Host Path = /image.jpg
Remote Host Path =/cgi-bin/getimage.cgi?motion=1
Kind regards,
PacoLM
