Hi I'm wondering if anyone can tell me wath are the posible attributes that I can give to my card at modprobe.
For example
saa7134 card=72
tuner=
radio=
coring=
full_luma_range=
chroma_agc=
combfilter=
autoload=
triton1=
vsfx=
I just want to know what are those other modes for, and if there are others that I can apply to my card.
This are my card's p specifications.
I have 4 cams, three of them are running in separet frames but the capture of the forth one passes at the back of the other. I hope you understand.
Thank you very much!
I hope you can help me.
[root@XX]# zmu -q -d /dev/video0 -v
Video Device: /dev/video0
General Capabilities
Driver: saa7134
Card: RTD Embedded Technologies VFG73
Bus: PCI:0000:04:01.0
Version: 0.2.14
Type: 0x5000015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp gray (GREY)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
24 bpp RGB, be (RGB3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2 packed, YUYV (YUYV)
4:2:2 packed, UYVY (UYVY)
4:2:2 planar, Y-Cb-Cr (422P)
4:2:0 planar, Y-Cb-Cr (YU12)
4:2:0 planar, Y-Cb-Cr (YV12)
Crop Capabilities
Bounds: 704 x 480
Default: 704 x 480
Current: 704 x 480
Inputs: 6
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 3
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 4
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 5
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Help with config modes for saa7134
Taken from saa7134 driver in gentoo linux 2.6.31-gentoo-r6 kernel.
This is probably the most interesting one.. Can saa7134 chips can do deinterlacing?
module_param(noninterlaced, int, 0644);
MODULE_PARM_DESC(noninterlaced,"capture non interlaced video");
module_param(video_debug, int, 0644);
MODULE_PARM_DESC(video_debug,"enable debug messages [video]");
module_param(gbuffers, int, 0444);
MODULE_PARM_DESC(gbuffers,"number of capture buffers, range 2-32");
module_param_string(secam, secam, sizeof(secam), 0644);
MODULE_PARM_DESC(secam, "force SECAM variant, either DK,L or Lc");
module_param(antenna_pwr, int, 0444);
MODULE_PARM_DESC(antenna_pwr,"enable antenna power (Pinnacle 300i)");
static int use_frontend;
module_param(use_frontend, int, 0644);
MODULE_PARM_DESC(use_frontend,"for cards with multiple frontends (0: terrestrial, 1: satellite)");
static int debug;
module_param(debug, int, 0644);
MODULE_PARM_DESC(debug, "Turn on/off module debugging (default:off).");
module_param_array(video_nr, int, NULL, 0444);
module_param_array(vbi_nr, int, NULL, 0444);
module_param_array(radio_nr, int, NULL, 0444);
module_param_array(tuner, int, NULL, 0444);
module_param_array(card, int, NULL, 0444);
MODULE_PARM_DESC(video_nr, "video device number");
MODULE_PARM_DESC(vbi_nr, "vbi device number");
MODULE_PARM_DESC(radio_nr, "radio device number");
MODULE_PARM_DESC(tuner, "tuner type");
MODULE_PARM_DESC(card, "card type");
static unsigned int irq_debug;
module_param(irq_debug, int, 0644);
MODULE_PARM_DESC(irq_debug,"enable debug messages [IRQ handler]");
static unsigned int core_debug;
module_param(core_debug, int, 0644);
MODULE_PARM_DESC(core_debug,"enable debug messages [core]");
static unsigned int gpio_tracking;
module_param(gpio_tracking, int, 0644);
MODULE_PARM_DESC(gpio_tracking,"enable debug messages [gpio]");
static int debug;
static unsigned int alsa = 1;
module_param(alsa, int, 0644);
MODULE_PARM_DESC(alsa,"enable/disable ALSA DMA sound [dmasound]");
static unsigned int latency = UNSET;
module_param(latency, int, 0444);
MODULE_PARM_DESC(latency,"pci latency timer");
int saa7134_no_overlay=-1;
module_param_named(no_overlay, saa7134_no_overlay, int, 0444);
MODULE_PARM_DESC(no_overlay,"allow override overlay default (0 disables, 1 enables)"
" [some VIA/SIS chipsets are known to have problem with overlay]");
static unsigned int audio_debug;
module_param(audio_debug, int, 0644);
MODULE_PARM_DESC(audio_debug,"enable debug messages [tv audio]");
static unsigned int audio_ddep;
module_param(audio_ddep, int, 0644);
MODULE_PARM_DESC(audio_ddep,"audio ddep overwrite");
static int audio_clock_override = UNSET;
module_param(audio_clock_override, int, 0644);
static int audio_clock_tweak;
module_param(audio_clock_tweak, int, 0644);
MODULE_PARM_DESC(audio_clock_tweak, "Audio clock tick fine tuning for cards with audio crystal that's slightly off (range [-1024 .. 1024])");
static unsigned int debug;
MODULE_PARM_DESC(debug,"enable debug messages [alsa]");
module_param_array(index, int, NULL, 0444);
module_param_array(enable, int, NULL, 0444);
MODULE_PARM_DESC(index, "Index value for SAA7134 capture interface(s).");
MODULE_PARM_DESC(enable, "Enable (or not) the SAA7134 capture interface(s).");
static unsigned int disable_ir;
module_param(disable_ir, int, 0444);
MODULE_PARM_DESC(disable_ir,"disable infrared remote support");
static unsigned int ir_debug;
module_param(ir_debug, int, 0644);
MODULE_PARM_DESC(ir_debug,"enable debug messages [IR]");
static int pinnacle_remote;
module_param(pinnacle_remote, int, 0644); /* Choose Pinnacle PCTV remote */
MODULE_PARM_DESC(pinnacle_remote, "Specify Pinnacle PCTV remote: 0=coloured, 1=grey (defaults to 0)");
static int ir_rc5_remote_gap = 885;
module_param(ir_rc5_remote_gap, int, 0644);
static int ir_rc5_key_timeout = 115;
module_param(ir_rc5_key_timeout, int, 0644);
static int repeat_delay = 500;
module_param(repeat_delay, int, 0644);
MODULE_PARM_DESC(repeat_delay, "delay before key repeat started");
static int repeat_period = 33;
module_param(repeat_period, int, 0644);
MODULE_PARM_DESC(repeat_period, "repeat period between "
"keypresses when key is down");
static unsigned int disable_other_ir;
module_param(disable_other_ir, int, 0644);
MODULE_PARM_DESC(disable_other_ir, "disable full codes of "
"alternative remotes from other manufacturers");
static unsigned int i2c_debug;
module_param(i2c_debug, int, 0644);
MODULE_PARM_DESC(i2c_debug,"enable debug messages [i2c]");
static unsigned int i2c_scan;
module_param(i2c_scan, int, 0444);
MODULE_PARM_DESC(i2c_scan,"scan i2c bus at insmod time");
static unsigned int tsbufs = 8;
module_param(tsbufs, int, 0444);
MODULE_PARM_DESC(tsbufs, "number of ts buffers for read/write IO, range 2-32");
static unsigned int ts_nr_packets = 64;
module_param(ts_nr_packets, int, 0444);
MODULE_PARM_DESC(ts_nr_packets,"size of a ts buffers (in ts packets)");
static unsigned int vbi_debug;
module_param(vbi_debug, int, 0644);
MODULE_PARM_DESC(vbi_debug,"enable debug messages [vbi]");
static unsigned int vbibufs = 4;
module_param(vbibufs, int, 0444);
MODULE_PARM_DESC(vbibufs,"number of vbi buffers, range 2-32");
