the presets are just that. You will need to tune them for your view. If the monitor is contantly in alarm it wont end until the alarm ends.
is your box public?
1.24.2 Alarm events not ending
James Wilson
Oh sorry.
No, it's not public, but i can set up a temporary password,
if you give me and e-mail i can send it to.
mine is: trasherdk@fumlersoft.dk
Enjoy
TrasherDK
TrasherDK
ok i have had a look.
But events are ending? You have a few events.
What else have you altered on this other than sensitivity?
James Wilson
Thanks.
Nothing changed, other than change from "Best - High sensitivity"
to "Best - Medium sensitivity".
Well, events end because i SIGHUP the zma process, when i see
that nothing is going on that should cause an event.
Anyway, i'll leave it alone for a while, to see if these new settings make
a difference.
a difference.
Enjoy
TrasherDK
TrasherDK
i could do wwith seeing it when it occurs. When i looked high sens should of been fine.
James Wilson
