Hi! Guys: I recently purchased a 1M pixel camera but having some difficulties setting it up. The camera can run in either regular NTSC or Hi Def mode, under NTSC everything is fine, but when I hook up the Hi Def channel, the picture I saw keeps jumping left/right, up/down raplidly, it's like oscillation or something.
I set the Device Format to NTSC and Capture Palette to RGB55, Capture size is 540x480.
Obviously above setting is wrong, but I have no idea what it should be. is there a way to check?
Here is the output from "zmu -d /dev/video4 -q -v":
Video Device: /dev/video4
General Capabilities
Driver: bttv
Card: BT878 video (ProVideo PV150)
Bus: PCI:0000:04:0b.0
Version: 0.9.18
Type: 0x5000015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
8 bpp, dithered color (HI24)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2, packed, YUYV (YUYV)
4:2:2, packed, UYVY (UYVY)
4:2:2, planar, Y-Cb-Cr (422P)
4:2:0, planar, Y-Cb-Cr (YU12)
4:2:0, planar, Y-Cr-Cb (YV12)
4:1:1, planar, Y-Cb-Cr (411P)
4:1:0, planar, Y-Cb-Cr (YUV9)
4:1:0, planar, Y-Cr-Cb (YVU9)
Crop Capabilities
Bounds: 838 x 504
Default: 768 x 480
Current: 768 x 480
Inputs: 2
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
And here is dmesg:
bttv: Bt8xx card found (4).
bttv 0000:04:0b.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
bttv4: Bt878 (rev 17) at 0000:04:0b.0, irq: 23, latency: 132, mmio: 0xf8106000
bttv4: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
bttv4: using: ProVideo PV150 [card=98,autodetected]
IRQ 23/bttv4: IRQF_DISABLED is not guaranteed on shared IRQs
bttv4: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv4: tuner absent
bttv4: registered device video4
bttv4: registered device vbi4
bttv4: PLL: 28636363 => 35468950 .
bttv4: PLL: 28636363 => 35468950 . ok
bttv1: PLL can sleep, using XTAL (28636363).
bttv2: PLL can sleep, using XTAL (28636363).
bttv3: PLL can sleep, using XTAL (28636363).
bttv4: PLL can sleep, using XTAL (28636363).
Issue with High Definition camera. Please help
Sorry, my mistake, I poked the wrong camera. here is the correct zmu output:
Video Device: /dev/video0
Driver: bttv
Card: BT878 video ( *** UNKNOWN/GENER
Bus: PCI:0000:03:0a.0
Version: 0.9.18
Type: 0x5000015
Does not have tuner
Does not have radio
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
Crop Capabilities
Bounds: 838 x 504
Default: 768 x 480
Current: 768 x 480
Inputs: 4
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 3
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
And here is the dmesg:
bttv: driver version 0.9.18 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv 0000:03:0a.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
bttv0: Bt878 (rev 17) at 0000:03:0a.0, irq: 22, latency: 132, mmio: 0xf8000000
bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
IRQ 22/bttv0: IRQF_DISABLED is not guaranteed on shared IRQs
bttv0: gpio: en=00000000, out=00000000 in=00f360ff [init]
bttv0: tuner type unset
bttv0: registered device video0
bttv0: registered device vbi0
Driver: bttv
Version: 0.9.18
Type: 0x5000015
Does not have tuner
Does not have radio
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
Crop Capabilities
Bounds: 838 x 504
Default: 768 x 480
Current: 768 x 480
Inputs: 4
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 3
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
ntsc cant do megapixel, the std is limited to 640 x 480.
id try running the card at full res and see if that helps.
Other than that increase the frame grab setting. but id try the res first
James Wilson
Could you please be more specific. What do you mean by running the card at full resolution?
I wonder if my card actually support High resolution. Is there a way to tell?
jameswilson wrote:ntsc cant do megapixel, the std is limited to 640 x 480.
well if you have a normal interline transfer cam then runnng at full res will give interlace issues.
However i would test it at that first.
What i dont understand is your '1M camera' that is NTSC?
James Wilson
The camera has two BNC heads. One is NTSC which works fine with my zoneminder, the 2nd BNC head is for High definition which I am having trouble with. I don't know what format of video the 2nd BNC head outputs. The manual doesn't say that, it just say it is Hi Def.
How do I do the test?
jameswilson wrote:well if you have a normal interline transfer cam then runnng at full res will give interlace issues.
I have heard of these. As far as i know its a new high def std for coax. I was reading about it in a trade press release.
afaik there is no cards that can do this yet, however there are one or 2 dvr's.
Its designed as a std to get megapixel without ip, ie upgrades on existing cable etc.
James Wilson
